Rotational/rocking noise from engine when lifting off from accelerator
Old Apr 20, 2006 | 06:27 AM
deserTTcruiser's Avatar
Default Rotational/rocking noise from engine when lifting off from accelerator
I once complained about an identical noise <a href="https://forums.audiworld.com/tt/msgs/984996.phtml" target="_blank">here</a> (in Dec, 2003).
I never managed to properly identify the noise previously or solve it despite switching to a Forge DVR, but I wasn't overly concerned since it was intermittent and never became any worse.
However, it is suddenly happening even at standstill and when the gear is in neutral. It seems that I have to rev it to at least 2.5K to be able to hear the noise, and the noise is louder at higher engine speeds.
The dealer seems to think it is the turbo, but I don't buy that at all. Does the turbo even spin with no load? If it is the turbo, why can't I hear it under acceleration? Note that the performance of the car does not seem to be any worse.
Also, the dealer has checked the exhaust and downpipe for any movement that may be causing the noise and found nothing.
One other thing, I have also recently noticed that the car now emits a honk of sorts under strong acceleration. This is probably due to a torn diaphram or loose clamp/hose - right?
Could the two noises be related?
Thanks in advance for your help.
Old Apr 20, 2006 | 07:00 AM
kodeTT's Avatar
Elder Member
Default check your motor mounts...and also your pendulum mount as well.
if you still have the OEM mounts in...the rubber may be cracked there in one of the three spots, causing the noise.
i took my pendulum mount out after 15K miles and one of the bushings was torn. alot of stress there from the motor.
Old Apr 20, 2006 | 07:08 AM
Default Switched to Powerflex about 6 months back and it didn't effect the noise at all...
And I just had them check at the dealer and they say the mounts are fine. Any other thoughts?
Old Apr 20, 2006 | 08:04 AM
Default Correction...
I just took another drive and the sound I reported back in 2003 is not the same as this new sound as I am able to hear both if I listen closely.
The original sound from 2003 was more mechanical/metallic sounding whereas this new sound has more of a breathy quality.
I am still unsure of what is causing either though.
Old Apr 20, 2006 | 09:15 AM
GeTT da NeTT's Avatar
Default Funny sounding noises (FSNs) are difficult to diagnose in person, virtually impossible here. It
could be many different things.
The honking sound is your DV, most likely.
Old Apr 20, 2006 | 10:17 AM
Thanks. I'll try to record the sound tomorrow and post it.
Old Apr 21, 2006 | 11:52 PM
Default Here is the best recording of the noise that I could manage...
<a href="http://media.putfile.com/TT-Engine-Noise-MP3-format" target="_blank">Click here to hear 'TT-Engine-Noise-MP3-format'</a>
Justin517
Aug 5, 2004 08:01 AM
JJsLegacy
Feb 12, 2004 03:27 PM
Shoe
Aug 27, 2002 09:27 PM
jsbear
May 9, 2001 08:15 PM
donp@audiworld.com
10
Mar 1, 2000 05:46 PM
