Bad Gas = Bad fuel gauge?? Kind of Long.
Old Apr 20, 2006 | 07:55 AM
Wide Bomber's Avatar
New Member
Default Bad Gas = Bad fuel gauge?? Kind of Long.
Last week I let my step-father use the car for a joy ride and I told him to fill the gas tank after he was done. That was on a Sunday.
Monday I go to use the car and I see the fuel gauge full. Fine. I use the car all week and the fuel gauge still says full. I use up all that foul gas and I fill up at my regular gas station, with premium. Now the fuel gauge seems to be fine.
I asked my step father, if he used premium and he said yes and then I asked him where he filled up and he told me at my regular spot.
I think he is lying...or he just doesn't remember. Because I let him use the car last month and he forgot to turn the lights off, so my battery died.
Has there been anybody else with this knid of problem?? TIA
Old Apr 20, 2006 | 08:29 AM
fredfromny's Avatar
Audi = Bad fuel sender.
Old Apr 20, 2006 | 08:32 AM
mad scientist's Avatar
Junior Member
Default Yes.
My fuel gauge will go wacky (usually reads low-->0) when I use some particular brands of fuel. So I steer clear of them.
--Tim--
Old Apr 20, 2006 | 08:36 AM
bubba j's Avatar
AudiWorld Expert
Others have had good results with a bottle of Techron.
Old Apr 20, 2006 | 08:44 AM
PGTT's Avatar
Default Bad fuel sending units and/or bad instrument clusters are to blame.
Common problem, do a forum search.
But in a nutshell, if 1-2 treatments of Techron do not help and the problem continues, then you need to pull & physically clean the fuel sending units (there are 2 in the gas tank, complicated process) or replace the fuel sending units (self or through dealer); and/or you need a new instrument cluster (through dealer and expensive if not in warranty).
I had my cluster replaced once for this while still under warranty.
Old Apr 20, 2006 | 08:48 AM
Greg225TT's Avatar
Junior Member
Default No, because I will not let my stepfather drive my car! ....
I have had the fuel sending units go out, however my fuel guage would drop to under 3/4 right after I filled up. It never stayed stuck at full.
Old Apr 20, 2006 | 08:52 AM
RoberTT-WWCD's Avatar
Default What Peter said. I was having the same problems and after a month of doing...>>
the Techron cleaning, I had to clean the primary sender.
Easy solution. You don't need the Audi special tool as some have used other methods to remove the retainer.
Hope this helps.<ul><li><a href="http://images5.fotki.com/v73/photos/5/58883/297210/DSCN2158-vi.jpg">Cleaning sender...</a></li></ul>
Old Apr 20, 2006 | 08:54 AM
PGTT's Avatar
Default Easy says you. ;)
You should start a cottage business cleaning and refurbing TT FSUs!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 20, 2006 | 08:55 AM
I can do. Maybe I can start at TT-West...;-)
PGTT's Avatar
Default Money for the beer fund!
Or scotch fund!
