New Battery draining...>
I'll post something if we figure mine out.
Rich
Key on (DO NOT TRY TO START ENGINE)for a few seconds and shut off. Remove key get out and lock the car using remote. After a few minutes the amp draw should drop to about 30 milliamps or lower. If it does not drop you are looking at a current drain somewhere. You can keep the drivers door open and simply lock the door latch to fake closing the door. Now you can start removing fuses to isolate where the drain is coming from.
