If anyone can help. Can't find anything in the search...
Old Apr 23, 2006 | 11:07 AM
Basttion's Avatar
Default If anyone can help. Can't find anything in the search...
Do you know of a 12v wire to tap that is only powered while the car is locked with the remote?
TIA!
Old Apr 23, 2006 | 11:44 AM
GeTT da NeTT's Avatar
Please clarify. What are you trying to do?
Old Apr 23, 2006 | 11:59 AM
Basttion's Avatar
Default Trying to find a wire that only has power while the car is off and locked...
Like the wires going to the blinking LEDs. I'm thinking of wiring up an LED scanner that comes on when the car is armed with the remote.
TIA, Case!
Old Apr 23, 2006 | 01:56 PM
Default The LED circuits are very low power and are controlled thru the locking circuit. How much power do
you need? They also pulse, which I'm reasonably certain, you don't want.
Old Apr 23, 2006 | 03:36 PM
Basttion's Avatar
Right, the LEDs were just an example. I need 12v constant but only while locked and armed...
Old Apr 24, 2006 | 08:43 AM
maaliish's Avatar
Default good luck...don't think it will be easy to find. You can probably
use a relay to get good 12V, just need to find a good triger for the relay. I'm thinking motion sensor
Old Apr 24, 2006 | 01:34 PM
SpideyTT!!!'s Avatar
Default I think there is a light on the interior lock/unlock button...
...which turns on when the doors are locked.
Unfortunately, I don't know whether it is on when the ignition is off...
AudiSport44
Sep 14, 2010 12:48 PM
05 Cab 2.5TDI Sport
Mar 16, 2008 09:38 PM
aerohr
Mar 20, 2006 04:09 PM
audi90man
Jan 26, 2005 05:50 PM
UrSoccer_mobileĀ®
Sep 27, 2003 06:14 PM
