3.2 DTC (Diagnostic Trouble Code)!
So I posted on AKEURO.com and asked if someone could hook me up with a VAG COM (I think that's going to me my next "mod". A member on the forum met up with me and used his DTC. The codes that came up were P0507, P2187 & P2189.
We found out what P0507 was which is Idle Control System Higher than Expected.
As for the rest, I have no clue (It wasn't in his book). So I came back and searched for it online and found similar DTC's but rather than a 2 after the P, there's a 1. They are...
P1187 Linear 02 Sensor / Compens. Resistor Open Circuit
P1189 Linear 02 Sensor / Compens. Resistor Short to B +
Can someone check on the P2187 & P2189 for me? & do you think when I take it into the Audi dealership they'll blame it on the VTDA intake that I have? If so, I'll get my roommate back up in Tok to Express it down to me before I take it in. Also, here's another dumb questions...is this covered under warranty (if they don't end up blaming it on the air intake)?
Thanks for your help everyone.
1187 and 89: Fuel air metering..
Got a Vac leak somewhere? Could also be a MAF. Might try cleaning to start..
If you still have access to the VAG, check Block 32 for adaptation values for the MAF
