TTDA owners, how many miles before cleaning the K&N filter inside the TTDA?
Old Apr 23, 2006 | 07:27 PM
Ben3.2TT@BC's Avatar
Member
Default TTDA owners, how many miles before cleaning the K&N filter inside the TTDA?
Which is easier to use for lubrication, the spray can or the squeeze oil bottle?
Old Apr 23, 2006 | 07:46 PM
TToro 3.2's Avatar
Junior Member
Default The spray is easier.. Cleaning depends on your environment. dusty, crappy, rainny, then..>
more often. I'd say 10 to 15k..
Old Apr 24, 2006 | 03:36 AM
RoberTT-WWCD's Avatar
Default Check the filter every 5K and clean as necessary...>>
Get the spray cleaning kit. Put a light film of oil on and let it dry overnight for best results.
Old Apr 24, 2006 | 04:00 AM
ITALSKIER's Avatar
about 15k give or take......but if its in a very dusty environment...Id clean it sooner......
Old Apr 24, 2006 | 06:20 AM
That damn Dan's Avatar
LOL!!! The sticker that came with it says 75,000 miles.
Old Apr 24, 2006 | 06:40 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
:-)....That's when you have it on Low Suck Mode....
Old Apr 24, 2006 | 06:44 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Use the spray definitely....>
Much easier to do a light mist for the correct application. Cleaning frequency depends totally on your envoirnment and feed set-up. Front feeds definitely need cleaning more frequently as the pull in a lot of junk. 5K recommendation there. High feeds, clean envoirnment then 10-15K. Best just to look at it though. Peek through the feed end. Dirty=time to clean
Old Apr 24, 2006 | 07:46 AM
Member
Default Thanks guys. I will pop by the auto parts store and get the spray lubricant.
Another question, should I get the cleaning product manufactured by K&N or diluted simply green would work fine in this application? Thanks again!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 24, 2006 | 07:55 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Get the whole kit...>>>
They sell it with both products for around $10. The cleaner is specially formulated to work on the gauze material. Spray, let sit a bit, rinse with water, dry and re-oil. The instructions come on the box..
Old Apr 25, 2006 | 08:14 AM
Member
Thanks Steve!!
S4andTLS
May 27, 2008 11:15 AM
MoAK
Oct 26, 2005 03:46 AM
blueT28EnYcEe
Jul 30, 2003 09:28 AM
Shoe
Oct 7, 2002 06:41 AM
BLKPERL
Mar 11, 2002 12:10 PM
