Custom exhaust question.
Old Apr 25, 2006 | 02:58 PM
HugeTTs's Avatar
Default Custom exhaust question.
I've seen a few exhaust threads that sink pretty quick.
I want to sum up and make a good call here pretty soon.
First with some questions...
*After the cat, what is the best diameter piping to go with.
*Is there a way to do the duals without having a T in the exhaust (I've heard T's are bad news, they slow down the flow, correct me if I'm wrong)
*If I were to go with the most used size (2.5 or 3 inch I'm assuming, we will see the consensus once this thread has a little exposure) what can expect to hear everyday when I'm drving, will it be insaaanely loud, or just loud under acceleration?
*Would the use of an aftermarket resonator be a good idea to chill the flow down a little?
*Can I use my stock tips?
I put custom 2.75 inch piping on my Triumph TR6, headers straight straight into a flowmaster 40 series muffler. It was simple, one pipe to mess with and a muffler.
Here I'm dealing with duals and the unknown land of turbo cars... so I need your help!
Thanks again guys. I'm learning ALOT here.
-Chip
Old Apr 25, 2006 | 03:12 PM
nikhil's Avatar
Default some answers
i don't think there's a 'best' diameter for a cat-back system. some have gone with 2.75" while others choose 3". by a "T" in the exhaust, do you mean that the single pipe is splitting into the duals at a 90* junction? I think a "Y" in the pipe would be a better design for flow reasons, but I'm just speculating.
I had my cat-back system on the car for a couple weeks w/o a resonator, and honestly it was far too loud for me. Consequently, I added a fairly small resonator, which has helped a lot. I might change that resonator out for something a bit bigger to further dampen the sound a bit, but we'll see how it goes...
My current setup is pretty loud when accelerating but isn't all that loud when just cruising, although certain RPMs can be a bit annoying with the windows up.
You could use your stock tips, but bigger tips look much nicer :-)
i hope that helps a bit.
Old Apr 25, 2006 | 03:35 PM
HugeTTs's Avatar
Default Perfect, another question
Perfect.
So, I do a y pipe, and go with 3 inch pipe.
Would this be a good choice for a car with the GIAC 91 program?
I will pretty much be stock except for suspension/brake mods. The 91 program would be the only thing to increase engine performance.
Yay or nay on the 3 inch.
Which sounds better, that's what I'm most concerned with.
Old Apr 25, 2006 | 03:53 PM
aTTicism's Avatar
Default Re: Perfect, another question
Just do a Borla catback. From TT Forums search that seems to be the one many people like.
Old Apr 25, 2006 | 03:55 PM
GeTT da NeTT's Avatar
Default 3" pipe would provide better flow with potential future mods. For your application, choose the low
cost option and you will be happy.
Old Apr 25, 2006 | 04:02 PM
nikhil's Avatar
should be just fine...ygm
Old Apr 25, 2006 | 04:20 PM
fredfromny's Avatar
Default Grab the book: Maximim Boost by Corky Bell
Best diameter depends on final turbo set up.
If you're keeping stock DP + Cats, 3 inches may be overkill.
coasTTal's Avatar
Default Got an APR exhaust I will sell you.......
Got rearended in Dec. and got my APR exhaust replaced. Ran the exhaust for a couple months before the body shop replaced it.
Only damage is to the center pipe that got kinked a bit and the bottom of one tip got a little scraped.
Would make an excellent system to work from.
4bills + shipping.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 25, 2006 | 04:36 PM
HugeTTs's Avatar
Default Re: Got an APR exhaust I will sell you.......
Would you mind emailing me pictures. I was thinking about just buying a used system... I plan on replacing tips anyway.
VanHalenMan@aol.com
Old Apr 25, 2006 | 04:49 PM
Basttion's Avatar
The Borla DOES sound nice. I heard one for the first time at the Deals Gap GTG. It's sweeeeeeTT!
