I just ordered new RH AG Cup wheels 18x8.5 18x10 What size tires should I be getting
Old Apr 26, 2006 | 11:17 AM
drewmantt's Avatar
New Member
Default I just ordered new RH AG Cup wheels 18x8.5 18x10 What size tires should I be getting
I have 2001 Roadster Quattro in PA.
I was looking at the 17' but like the look of the 18".They won't arrive for about 8 weeks on backorder till then.What is the tire size I should runon the 18".
I know on the 17"
17x8=245/45/17
17x9=275/40/17 these sizes will give me an overall
diameter of 25.7
Is this right?
18x8.5=225/40/18
18x10=255/35/18 I was looking at the BF Goodrich G-force T/A KDW but with their tire sizes it would come out in the sizes listed as an overall diameter of 25.1 up front and 25.0 on the rear. Will this cause any problems?
Any input from anyone would be great.
Old Apr 26, 2006 | 12:32 PM
TonyStarkz's Avatar
that's the exact recommended setup.
Old Apr 26, 2006 | 02:49 PM
BlueChip's Avatar
Default Be careful with 225s on a 8.5" rim. The diameter is not the only dimension you should be looking at.
I ordered a set of Falken Ziex ZE-512 225/40ZR18 tires fitted to 5zigen/fn01r-c 18x8.5 wheels and they looked like shi#. The reason is that the tread width is only 7.7" (taken from the Falken website) (although 225mm is supposed to be 8.9") and the rim width is 8.5". The wheels stick out like sore thumbs. I changed my order to 235/40ZR18 tires which have a tread width of 8.2". Haven't received them yet to tell you what they look like but they should be a big improvement. The down side of the 235s is that the diameter increases to 25.5". I'm not sure if this "short" tread width is peculiar to Falken or if it applies to all tires.
The same applies for the Falken 255/35ZR18 which have a tread width of only 8.8" to go on your 10" rims.<ul><li><a href="http://www.falkentire.com/tires_512_sizes.htm">http://www.falkentire.com/tires_512_sizes.htm</a</li></ul>
Old Apr 26, 2006 | 03:38 PM
Morio's Avatar
Default That is what I was going to go with!
but i got a deal on the 17's..... I have the 17x8 with a 225-45-17 BFG G-Force Sports no tire stretch what-so-ever... I think you will be fine running that on a 8.5 width wheel!
Old Apr 26, 2006 | 04:01 PM
Sully's Avatar
Member
Default That will look awesome. Would like to do that with my FWD TT...
but should get me some good wheel locks based on my last mistake.
Potomac-Greg
Mid Atlantic Discussion
Aug 23, 2006 06:12 AM
evilaudi01
Wheels & Tires Discussion
Feb 2, 2005 10:09 AM
AJN334
Jan 25, 2005 12:19 PM
DJ WAFFELZ
19
Dec 15, 2003 09:52 AM
KeremD
Feb 21, 1999 12:30 AM
