Easy (read:Cheap) under-hood Bling - SS Strut Bar Nuts
An Easy fix and dress-up to the black OEM nuts are Stainless Steel Acorn nuts.
These are Stainless, not chrome-chrome is available.
<img src="http://www.loomknitting.com/auditt/images/acorn1.jpg">
<img src="http://www.loomknitting.com/auditt/images/acorn2.jpg">
<img src="http://www.loomknitting.com/auditt/images/acorn3.jpg">
Parts are sourced from McMaster-Carr.
Part Number: 94000A039 $7.12 per Pack of 10
M8 - Metric Thread Pitch1.25 mm
Thread Depth7.87 mm
Thread Direction Right-Hand Thread
Width 13 mm
Height 15 mm
Add to it a SS spring washer, as a lock washer.
(look closely, they are there.)
You may want to increase this to 18 or 20 mm, but the 16 is just fines, matches the OEM flange nut.
Part Number: 96475K236 $7.62 per Pack of 12
Outside Diameter 16 mm
Minimum Thickness .9 mm<ul><li><a href="http://www.mcmaster.com/">mcmaster.com</a></li></ul>
