Battery install took a bit longer than expected...
Old May 23, 2006 | 04:38 PM
GoTToGo's Avatar
Junior Member
Default Battery install took a bit longer than expected...
Couldn't find the Optima with reversed polarity at Autozone or Advanced Auto, so went to Sears (they didn't have the Optima either) and purchased a DieHard.
22833347 DieHard International BCI Group: 47 OEM Amps, 480 CCA
Thought it would be an easy pull and drop; turned out that in addition to the std 10mm socket, you need a 13mm to release the battery from the bottom. Also the DieHard is a tad bit shorter than the OEM so I had to notch out the battery holder on the +ve side with a cutting wheel on a dremel.
<img src="http://pictureposter.audiworld.com/55263/battery.jpg">
Old May 23, 2006 | 08:40 PM
Vegas-roadster's Avatar
25 Year Member
Default You were lucky depending on the model of the holder you could have needed more dremeling
Several holders have notches in the bottom that don'e match the bottom of most batteries. Seems Audi changed this part frequently, even during a model year so there is no way to find out what you need to do before pulling the battery.
Old May 23, 2006 | 09:07 PM
TTGram's Avatar
Member
Had to do that on mine as well.
esanmiguel
Oct 17, 2007 08:19 PM
dojo
Audi allroad
10
Aug 29, 2007 07:21 AM
77'911
Feb 6, 2007 02:39 PM
pat33
Sep 3, 2002 12:14 PM
