Any advice for painting rotor hubs
Old May 23, 2006 | 08:36 PM
Vegas-roadster's Avatar
25 Year Member
Default Any advice for painting rotor hubs
I got new rotors and dustless pads installed. Since my old rotors got so dirty from the pad dust, I did not give much thought to rust. However, my dustless pads work too well and you can see rust on the rotor hubs. In retrospect, I should have made sure the rotors were anodized but it is too late for that. Any advice on what paint to use to hide the rotor hub rust?
Old May 23, 2006 | 08:37 PM
whodkne's Avatar
Member
Default Not sure how it will work, but at least use a high temp paint...
Same kind of thing you would use to coat calipers.
Old May 23, 2006 | 08:41 PM
25 Year Member
Recommendations for paint brand or retailer?
Old May 23, 2006 | 08:52 PM
XCLR8TT's Avatar
Senior Member
Use the same paint that they make for Calipers. Your local Autozone should carry it.
Old May 23, 2006 | 09:14 PM
whodkne's Avatar
Member
Like was said, major car parts places carry stuff.. I bought Krylon high temp, I think.
Old May 23, 2006 | 09:23 PM
MiTThril's Avatar
Default Re:Funny you should ask! I just got done ordering .....
paint for my new rotors! Most caliper paint is sold as "caliper, drum, and hub" paint- look under "Caliper paint" on Ebay for lots of choices if you can't find what you want locally. I ended up ordering 2 kits, one each of black and white so I can mix up some grey to match the original rotor hubs on my '02 TT. Also, you might check with a company called Caswell Inc.- they have a huge selection of paints I've never seen before, including one by VHT called Nucast iron, good for 1500 degrees that I'm going to spray on the rotor vanes to see if I can keep the rust down there, too.
Old May 24, 2006 | 05:56 AM
YosemyTT's Avatar
Same problem here. I got a black caliper paint set to paint the rotor hubs.
DesmoTesta
Nov 6, 2006 12:54 PM
Jonathan Ross
14
Mar 4, 2006 06:51 PM
Pelican Pete
Jul 25, 2005 06:13 PM
SCAudiFan
21
May 13, 2005 03:46 PM
Fifth Screw
Wheels & Tires Discussion
Dec 19, 2001 07:45 AM
