R compound tyre break in question......
Old May 24, 2006 | 04:00 PM
Kareem of Elise's Avatar
Default R compound tyre break in question......
as you may remember, my wife bought me some R compound tyres for autocross for my b-day. Prior to this I was borrowing Ed's R compound tyres as he wasn't using them at the time.
Well, now I've got my Hoosier A3S05 tyres mounted on my stock fat fives. I noticed they didn't offer heat cycling on the web site and it doesn't really have a whole lot of break in tips on the site.
My question is: should I put them on the car prior to Sunday's autocross and kind of scuff them a bit lest they be a little slick? Also, if I'm primarily going to be doing Solo with them, do I need to worry about heat cycling?
Old May 24, 2006 | 04:04 PM
MOBlueTT's Avatar
Member
I recommend driving S L O W L Y around the AutoX course - you can't be too careful ;-P
Old May 24, 2006 | 04:06 PM
MOBlueTT's Avatar
Member
Default ok so read here >>>
The first time a competition tire is used is the most important. During that run, its tread compound is stretched, some of the weaker bonds between the rubber molecules will be broken (which generates some of the heat). If the tires are initially run too hard or too long, some of the stronger bonds will also be broken which will reduces the tire's grip and wear qualities.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&amp;url=%2Ftires%2Ftiretech%2Ftechpage .jsp%3Ftechid%3D66">http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=66</a></li></ul>
Old May 24, 2006 | 04:12 PM
MOBlueTT's Avatar
Member
Default and this from CDW on Heat Cycle >>>
A tire that has been heated up through use and then cooled down has experienced one heat cycle. This often results in a slight hardening of the tire compound, which can make the tire perform at a high level for a longer period of time. See Scrubbed Tires.
SCRUBBED TIRES
Tires which have a few laps on them to remove the outer sheen and provide more consistent traction.
Old May 24, 2006 | 04:16 PM
MOBlueTT's Avatar
Member
Default 1st cycle IS the most important >>>
<ul><li><a href="http://www.porschenet.com/bfgtires.html">http://www.porschenet.com/bfgtires.html</a</li></ul>
Old May 24, 2006 | 04:52 PM
the Quiet sTTorm...'s Avatar
Member
hes's setting you up Paul! It will be interesting to see this weekend results.
Old May 24, 2006 | 04:58 PM
MOBlueTT's Avatar
Member
I'll be running as "The Quiet MOBlueTT" ;-P
Old May 24, 2006 | 04:59 PM
jrok's Avatar
Junior Member
Default Some of this info may be helpful...
<ul><li><a href="https://www.hoosiertire.com/Tctips.htm">Hoosier Tips</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old May 24, 2006 | 05:04 PM
Member
Mount them on the car and run them gently on the highway for a couple of miles. bring home and sit.
Old May 24, 2006 | 05:05 PM
Member
I made sure I got those tires back to STL to see the results from Sun : )
