Is it possible if the dealer is changing the codes for
Old May 25, 2006 | 12:24 PM
jcd1006's Avatar
New Member
Default Is it possible if the dealer is changing the codes for
the door locks, so that it locks once over 15MPH and also the code to roll the windows down/up using the keyless entry to mess up the APR chip or anything like that, without them knowing it's been upgraded?
Old May 25, 2006 | 12:35 PM
aTTicism's Avatar
Huh?
Old May 25, 2006 | 12:43 PM
jcd1006's Avatar
New Member
Default REvised for better explanation
I have an APR ECU upgrade. I checked with the dealer on changing a few codes in the computer, so that A.) the doors will automatically lock after the car reaches 15MPH and then will unlock once you take the key out of the ignition and B.) you can hold the unlock button the keyless entry and it will roll the windows down(before you get in the car) and you can hold the lock button and it will roll them up.
I am wanting to know if they can somehow erase the APR ECU upgrade when they go in and change those two codes? Sorry for the confusion.
unc99206's Avatar
Member
my dealer unknowingly unflashed my GIAC ecu
Old May 25, 2006 | 12:44 PM
Lowcountry's Avatar
Default I think he doesn't want his dealer to know he has chipped the car.
Warranty concerns.
Old May 25, 2006 | 12:45 PM
Lowcountry's Avatar
scratch that.
Old May 25, 2006 | 12:46 PM
Lowcountry's Avatar
What happened next?
Old May 25, 2006 | 01:00 PM
maaliish's Avatar
Default That procedure has nothing to do with your ECU, it recodes a different module.
Can the dealer erase APR programming? Anything is possible, but that has nothing to do with above procedure.
 Pouria Savadkouei
 Michael S. Palmer
Old May 25, 2006 | 01:07 PM
jcd1006's Avatar
New Member
Alright, I was just making sure, Thanks
Old May 25, 2006 | 01:08 PM
bubba j's Avatar
AudiWorld Expert
Maybe you should just find someone with a VAG-COM.
