Anyone know if you have to remove the upper back seats to get
Old May 25, 2006 | 01:19 PM
jcd1006's Avatar
New Member
Default Anyone know if you have to remove the upper back seats to get
to the cd changer. I'm about to install my ICe link and I want to see what all I have to remove. TIA
Old May 25, 2006 | 01:22 PM
XCLR8TT's Avatar
Senior Member
You have to remove the drivers side back to remove the panel.
Old May 25, 2006 | 01:34 PM
Seneb's Avatar
there are several good writeups on this
Old May 25, 2006 | 01:42 PM
rotuspeed3's Avatar
Member
Default I just did this
to install my phatbox. Search for the write ups. They suggest removing the rear seatback. You will also have to remove the post for seatback latch. The instructions say to use a deep socket, but I found that a double offset wrenches work MUCH better. I picked up a set from the cheap chinese tool store, less than $20.<ul><li><a href="http://ampcosafetytools.thomasnet.com/viewitems/all-categories/wrench-box-end-double-offset-type-12-point-metric-#">wrenches</a></li></ul>
Old May 26, 2006 | 12:36 PM
mobsTTa's Avatar
Default do you need to remove the panel? I think you can reach under the panel and
get to the cable to connect to the icelink. If so you don't need to remove the seat back. It's easier in the long run if you take out the seat back and the panel, but it may not be necessary
nemesisa6
Aug 18, 2008 07:09 AM
FrysSux
Jan 24, 2008 01:50 PM
CheeseHead Cubs Fan
15
Jun 3, 2005 02:41 PM
allgood
Audi allroad
May 1, 2005 08:17 AM
