16795
Old May 25, 2006 | 08:56 PM
KorTT's Avatar
Default 16795
new to TT, I was prepared, but probs started earlier than I expected
I am getting this stupid incorr. secondary air code and after a reset, it popped up in a couple mins after a cold start-and-go. Yes, I did a search and checked the neighborhood of combi valve for leaks but couldn't find any, everything seems to be holding tight. couldn't get the pump itself yet. I have a boost gauge (already installed when I got the car) and I wonder if this gauge can help me diagnose the prob. the vacuum is stable at 17-18inHg after idle is stabilized around 720-730rpm. It jumps around till idle rpm stabilizes tough. is this vac level normal?
this happened only a few days after the TB change at the stealership so any chance that the stelaers messed up the vac somehow?
the car is an APR chipped 2001 TTQC by the way.
and --how do I get a hold of the octane number of the chip?
thanks in advance
Old May 26, 2006 | 06:11 AM
GeTT da NeTT's Avatar
On teh chip, If you know who purchased the upgrade, you can call them and find out.
Old May 26, 2006 | 06:50 AM
MaxHedrm's Avatar
How noisy is the pump? It could be dying.
Old May 26, 2006 | 07:01 AM
maaliish's Avatar
Your vac seems ok. Probably an airpump on its way out. I'm in the same boat
Old May 26, 2006 | 08:36 AM
KorTT's Avatar
Default would VAG-COM work?
Thanks for your help.
I'll have the VAG-COM soon, could it help me figure out if the sec air pump is dying or not?
or the only way to find that out is to wait and see?
yea I can check if the pump works noisy or not but how much noise is noisy?
Old May 26, 2006 | 09:09 AM
maaliish's Avatar
Don't think so. You'll be able to reset the code but I don't think you can acutally test the pump.
Old May 26, 2006 | 09:26 AM
KorTT's Avatar
So what will happen when the pump dies?
Old May 26, 2006 | 09:58 AM
maaliish's Avatar
Default you'll have to replace it :-)
it will throw a constant code and it will probably be either loud as hell or not work at all. That pump heats up the cat and is used for emission system. It might even be covered under emission warranty which I think is 7 years, so dealer might cover the job.
 Pouria Savadkouei
 Michael S. Palmer
Old May 26, 2006 | 11:20 AM
007TT's Avatar
Default Re: 16795
You can easily check if the pump is functioning reasonably well by unplugging the pump output air hose (black plastic thingy) that connects to the combi valve. Put your hand over the hose opening, you should feel air pushing out forcefully. Hope this helps.
Old May 26, 2006 | 12:56 PM
KorTT's Avatar
under emission warranty, unless the car is chipped right
