Cat-back install notes (FAQs?)?
Old May 26, 2006 | 06:26 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Cat-back install notes (FAQs?)?
Got my Borla (grazi, grazi you know who you are). Looks straighforward, but eBahn/Bentley is remarkably silent in Section 26 about that. Sort of "OBTW"....
- advice?
- consternations?
- appropriate cuss words and tongue holds while forking this bad **** in?
TIA!
Old May 26, 2006 | 06:33 AM
GeTT da NeTT's Avatar
Wysiwyg. I've had good luck with "PB Blaster" to loosen up those corroded bolts.
Old May 26, 2006 | 06:37 AM
InTTruder's Avatar
WYSIWYG indeed! Looks relatively straightforward. Anything else need to come loose?
Old May 26, 2006 | 06:40 AM
XCLR8TT's Avatar
Senior Member
Default Nope, just loosen the coupling sleeve bolts drop the hangers and it falls out
Install in reverse order.
Old May 26, 2006 | 06:46 AM
InTTruder's Avatar
Excellent! Grazi !!
Old May 26, 2006 | 07:18 AM
stilljester's Avatar
Member
Default Here's my Borla Install Notes
<ul><li><a href="http://www.rpi.edu/~onksej/Audi%20Stuff/Audi%20TT%20Borla%20Exhaust%20Install.pdf">Great Choice</a></li></ul>
Old May 26, 2006 | 07:21 AM
InTTruder's Avatar
Kind thanks! Fabulous detail!
Old May 26, 2006 | 07:35 AM
l33tt's Avatar
Do you still have your center bracket?
 Pouria Savadkouei
 Michael S. Palmer
Old May 26, 2006 | 07:47 AM
Member
Default Yup its in the garage - I figured I'd hold on to it in case I have to put the OEM exhaust back on
Anythinh happening with the Pro-Vent?
Old May 26, 2006 | 08:03 AM
RoberTT-WWCD's Avatar
Default Not a hard install. But you do need a lift...>>
Pretty much unbolt the old and install the new. The clamp connecting the downpipe/cats can be reused. Just use penetrating oil to loosing the bolts. You will reuse the hangers too.
My install took around an hour.
One thing, You might not have the prblems aligning the tips as some here (including me) being you are using a single tip.
