gorTT - found in a search... ever find the cause of that vibration at idle with A/C on?
Old May 29, 2006 | 08:40 AM
DisTTracted's Avatar
New Member
Default gorTT - found in a search... ever find the cause of that vibration at idle with A/C on?
I'm having the same problem, was it a symptom of low referigerant? TIA
heres the post..
I have vibration at idle - not noticeable when A/C off
Posted by: gorTT on 2005-03-03 13:44:18
Account #: 53277
In Reply to: How common is engine vibration in TTs? posted by TTRicks on 2005-03-03 11:12:05
Minor cycling vibration - had the dealer look at it, and 'couldn't find anything'... But - it bothers ME - even though subtle - to the point I'd rather run w/the air off (will be a real problem when it heats up here). Someone here once responded it was (could be) a symptom of low referigerant
Old May 29, 2006 | 08:48 AM
VorsprungTT's Avatar
id like to know too. have the same problem, also it dosnt get as cold. need recharge?
Old May 29, 2006 | 08:58 AM
New Member
Default maybe, I havn't had mine recharged either...
its been two years so far but the air is still cold. how long does a charge last? I do use it a lot!
Old May 29, 2006 | 08:59 AM
OldSchool AG's Avatar
Senior Member
Default could be the drive belt tensioner or..
could be a bad compressor. if refrigerant gets low the a/c clutch is disengaged by the low pressure switch.
Senior Member
sealed system. you never have to recharge unless there's a leak. i don't think thats your problem
Old May 29, 2006 | 11:30 AM
mjTT's Avatar
New Member
Default Had this problem twice...1st time new compressor fixed it >>
now the car is well out of warrantee I'm basically ignoring the noise until something breaks. The performance of the AC doesn't seem to be adversely affected. A helpful guy at Audi said they can order in a generic brand compressor (same manufacturer as the Audi one) but basically half the price.
Old May 29, 2006 | 06:41 PM
GorTT's Avatar
Default If it doesn't get cold, I'd suspect the drivers side radiator fan first >
that's a common symptom, and hard to identify. There's an AC readout you can use to check the engine coolant temp - if it's high, like 105 or so by inference the fan is possibly out.
Old May 29, 2006 | 06:49 PM
GorTT's Avatar
Default Ha! My engine tanked lask May, a month or 2 after I wrote that - hydrolocked >
trying to drive through some curb-deep water in Houston - my dumb - so no, I didn't find the problem; don't have it anymore either though. Did the timing belt and a KMD pulley on the rebuild as well as some other items, so really can't say what the cause was. The ac does contribute some 'normal' vibration of course, just not the oscillating type I experienced.
 Pouria Savadkouei
 Michael S. Palmer
Old May 30, 2006 | 10:18 AM
New Member
oh man, I guess thats one way to fix it! ...just had the ECS belt kit put in but didn't solve it.
DisTTracted
TT (Mk2) Discussion
May 29, 2006 05:39 AM
canonicalman
Jan 4, 2006 03:27 PM
jaykray
Dec 16, 2004 06:45 AM
Ulf
Aug 1, 2003 02:09 PM
dresch
Misc. Models Discussion
10
Nov 14, 2000 08:47 PM
