Finished My Battery Relo and dropped dead weight
<img src="http://pictureposter.audiworld.com/80527/gauges_009.jpg">
As for my battery relo some of you may remember a week ago when I had the car up in the air, had dropped the tail of the car, and pulled the ballast off the end, only to find that I did not have the cables for the battery relo kit, which I had planned on doing at the same time? <img src="http://pictureposter.audiworld.com/80527/gauges_002.jpg">
Well the cables came in this week and I was able to finishing the battery relo. I love all the space in the engine bay, and will be looking at modifying the intake to take advantage of the space.
<img src="http://pictureposter.audiworld.com/80527/emptyenginebay.jpg">
I also am considering using the space for a remote oil filter and 1qt acusump mount. Haven't decided yet. Anyone have any expierience with th 1Qt model?<ul><li><a href="http://classifieds.audiworld.com/cgi-bin/classifieds/classifieds.cgi?db=autoparts&website=&lang uage=&session_key=447b2256342f5d98&search_ and_display_db_button=on&db_id=26283&resul ts_format=long&query=retri
<img src="http://pictureposter.audiworld.com/80527/minusbattery_2.jpg">
<img src="http://pictureposter.audiworld.com/80527/batteryrelotrunk.jpg">
<img src="http://pictureposter.audiworld.com/80527/batteryrelotrunk2.jpg">
For looks I was considering a smaller battery and making my own sealed unit. This box was really big. I was also considering when this battery dies to replace it with an Optima which does not need to be sealed and could be placed at an angle etc.
Another year or so and I'll probably change this around. The driver is my battery life.
As for cables, if you pull your fender covers you'll see a couple of 1/2' holes ready to be punched, they are about one in down from the other cables that are runing through that wall on both fenders. I simply made them 3/4 and added my grommets. I followed the brake lines all the way up from the rear on the drivers side. Not too woried about the weight driver vs passenger side as I pulled my 37lb ballast off the drivers side and pulled my 35lb battery off the drivers side and relo'd to passenger. The 5~7lbs of copper on the drivers side won't kill me.
