recently with a/c and econ off I can still feel cold air coming from the vents, and on a hot day...
Old May 30, 2006 | 10:40 AM
DisTTracted's Avatar
New Member
Default recently with a/c and econ off I can still feel cold air coming from the vents, and on a hot day...
anybody also had/have this problem? TIA
Old May 30, 2006 | 10:41 AM
New Member
could it be my air flap motor?
Old May 30, 2006 | 10:46 AM
evpho|chop's Avatar
yep, and warm air when the heat is on, it has always been that way in my car.
Old May 30, 2006 | 10:57 AM
jhoeppel's Avatar
Default me too... >
Isn't there some way to check air flap position from reading the vent panel readout? I vaguely remember this but keep forgetting to check my Bentley at home...
Old May 30, 2006 | 11:01 AM
GOFASTT's Avatar
econ on shuts a/c off--
Old May 30, 2006 | 11:26 AM
New Member
ohh, i'll have to do a search on that after work.
Old May 30, 2006 | 11:28 AM
New Member
right, both are off and I still feel air flow. unless a LED burnt out.
Old May 30, 2006 | 12:10 PM
TT_Nuge's Avatar
Senior Member
Default Econ OFF = A/C ON. ECON On (LED illuminated) means the A/C is off.
Don't know if it changed for certain years but I don't have an A/C button. Just the Econ button and when Econ is illuminated that means the A/C is off. When Econ is not illuminated then the A/C can go on as needed.
 Pouria Savadkouei
 Michael S. Palmer
Old May 30, 2006 | 04:52 PM
New Member
Default really, what year? I have...
a big pull out button for a/c (light is on when a/c is off) and a small button for econ, if both are off then just the a/c light is on (which means its off). that seams weird. do you have a picture of your a/c controls?
for as long as I've owned it I could have everything off and no air comes in through the vents, now its like I have econ on all the time.
Old May 30, 2006 | 05:00 PM
TT_Nuge's Avatar
Senior Member
Default Think we have a confusion of terms here.
Big pull out button on the left turns off the entire climate control system. When the system is on the Econ button controls whether the a/c compressor is on or off. Econ On = A/C compressor off, Econ Off= A/C compressor on if needed. SO I think ours are the same, just different terms.
