Does anyone know if the plastic splash-shield underneith the engine?
Old May 30, 2006 | 04:00 PM
TTontheREAR's Avatar
New Member
Default Does anyone know if the plastic splash-shield underneith the engine?
Is NEEDED!!! I was driving to connecticut from maryland and the bastards that did my oil change did not fix my splash shield and it broke on 95. Just need to know... if i need to get it replaced or can i drive without it? Thanks to all in advance... for your help!
Old May 30, 2006 | 04:05 PM
modesTT@work's Avatar
Ya you need it (long term) but should be Ok for a short time! Mileage will suffer and Don't speed!!
Old May 30, 2006 | 04:12 PM
furiousgeorge's Avatar
Default didn't think of that milage thing... but speeding (at least, driving 70) is why mine is off.
Was cracked from PO, and kept getting sucked off the bottom of the car.
Other than dirt, no problems otherwise.
TTagz's Avatar
Senior Member
Default nope, not necessary...
I've been without one for nearly 2 years and 30k miles.
Old May 30, 2006 | 04:51 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default BS...
Part of aerodynamics and cooling. Just because you don't notice a difference doesen't mean it isn't important...
Old May 30, 2006 | 04:57 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Get them to pay for it..>>
It's not cheap ($170 or so)
Old May 30, 2006 | 05:51 PM
TTagz's Avatar
Senior Member
they don't call it a sound deadening panel for nothing
Old May 30, 2006 | 06:11 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Aerodynamic aids...>>
Reduce lift, aid cooling to the engine compartment and turbo Via NACA style ducts etc...(all those bits in yellow are part of the Aero package)
<img src="http://images5.fotki.com/v85/photos/2/282664/1018713/bottomofTT-vi.jpg">
 Pouria Savadkouei
 Michael S. Palmer
Old May 30, 2006 | 06:27 PM
TTagz's Avatar
Senior Member
Default the question was is it needed...
and the answer is still, no it isn't. Yes it's better to have one, but no it won't hurt anything to not have it on there. The aero dynamic effect is minimal. The cooling ducts wouldn't be necessary if the panel weren't blocking everything off in the first place. The most noticible difference it makes is keeping the engine clean. At the time, they were priced nearly $300 and I couldn't justify it for that. I hear they've gone down to around $180 but that's still a lot for a piece of plastic. This dude should get the shop to pay for his. I'll probably cut my own out of sheet aluminum at some point.
Old May 30, 2006 | 06:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Only if you don't care.....>>
about high speed stability. My car was noticeably more nervous without the panel in place. TTinCT recently mentioned the same..
