FYI: fuel gauge prob and fix...
Old May 31, 2006 | 10:51 AM
djgonzo007's Avatar
New Member
Default FYI: fuel gauge prob and fix...
Problem: fuel gauge would go way past full when I filled up the tank and would show 1/4 of a tank left when empty.
To Fix the problem the dealer decided it wasn't the sender and replaced the whole instrument cluster. Seemed drastic to me but what do I care it's under warranty.
Anyways just thought I'd post since I'm unsure if this is a common problem.
I had the instrument cluster replaced on my B5 S4 as well but for another problem not related to the fuel gauge or any other gauge for that matter.
Cheers.
Old May 31, 2006 | 11:15 AM
RoberTT-WWCD's Avatar
Default Cleaned my primary sender a few months back. Problem solved...>>
other have tried Techron for a few fillups and fixed the problem.
I have pics on the fotki.
Old May 31, 2006 | 11:19 AM
FasTTr's Avatar
They replaced my cluster also - and then replaced the senders 2 weeks later when it was still broken
Old May 31, 2006 | 11:43 AM
djgonzo007's Avatar
New Member
It's been a week and so far and the gauge works fine but I'll watch it.
Old May 31, 2006 | 11:45 AM
blueprinTT's Avatar
Member
Default I have the exact same symptoms right now....
...Two treatments with Techron haven't helped at all yet. The "miles to empty" and fuel light are still accurate, which leads me to believe it is the fuel gauge in the cluster itself. Too bad they have to replace the whole cluster, but good thing it's still under warranty.
Old May 31, 2006 | 11:53 AM
FasTTr's Avatar
I agree. When the sender is bad the miles to empty calc screws up also.
Old May 31, 2006 | 12:20 PM
BAJITTO's Avatar
had my cluster replaced 2mos ago, now acting up again! will b making an appt soon still under warr.
Old May 31, 2006 | 01:16 PM
djgonzo007's Avatar
New Member
That was my problem as well... again so far replacing the cluster worked.
 Pouria Savadkouei
 Michael S. Palmer
Old May 31, 2006 | 03:12 PM
coasTTal's Avatar
I have had cluster fix the problem and also have senders fix the problem. 2x had this issue.
Old May 31, 2006 | 04:14 PM
pray4mojo's Avatar
Default had the exact issue and same solution...it worked
...also under ext. warranty (i was wondering if the dealer was sticking it to the warr co.)
