First Problem since having bought my TT...
) turbo gauge to come in so I can run the machine to it's full capacity. Other pottential prob- Engine was significantly hotter after about 5 mins of driving... Anyone else have a problem/ solution?
The engine heat was a serious concern however.
Perhaps you have your boost set too high with the new boost enhancer and your car is running hotter due to that.
In any event, Mr. Schwing will probably have an answer for you.
Also- what's the difference (if any) between a diverter valve and a turbo blow off valve? Which would you recomend, and would that help with cooling issues?
) I was just interested in the most efficient way to go about it. What works best!
