What's the highest Oil Temp. You Have Seen on Your TT?? ........
Old Jun 2, 2006 | 06:07 PM
coasTTal's Avatar
Default What's the highest Oil Temp. You Have Seen on Your TT?? ........
Got to make a bunch of laps in 3 segments this week at Gingerman Raceway up in South Haven, MI. I notice that my oil temp, which normally is around 200F was peaking at 280F.
I would park the TT and within 5 minutes of idling the temp. would be down to 220F.
I did a search and couldn't find much on temps you folks have seen.
This is certainly good impetus to get going with my oil cooler install.
Old Jun 2, 2006 | 06:12 PM
BluHeaven's Avatar
Default where are you installing the cooler?
are you adapting one from a n/a vdub to fit where a side mount IC used to be? or aftermarket mount in front of the radiator kind?
Old Jun 2, 2006 | 06:13 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Hard running and high altitudes..>>
lots of Turbo activity at TT-West, 235 with the cooler John. DO IT!
Old Jun 2, 2006 | 06:25 PM
coasTTal's Avatar
Default Going over on the passenger front side where the old IC was...
After seeing 280F, and even running Mobil 1, I need to make this a priority.
Old Jun 3, 2006 | 05:34 AM
TTinCT's Avatar
Rest In Peace
Default sounds like you need to do an oil cooler...those temps are high>>>
dyno oil begins to breakdown between 260-270...synthetic is higher...
Old Jun 3, 2006 | 05:41 AM
coasTTal's Avatar
Default Yep, got most the parts about 2' from me. ALWAYS run Mobil 1.
<center><img src="http://pictureposter.audiworld.com/24437/dsc_0967a.jpg"></center><p>
Old Jun 3, 2006 | 05:49 AM
TTinCT's Avatar
Rest In Peace
Default good deal....i noticed this week during a recent heat "wave" in NJ>>>>
95-97 deg....that poking in traffic with the a/c on, the car ran around 220...as soon as we were moving it settled in around 210....i have not done a track event, but if i did, i might consider a fan too....just in case, but it might be a little overkill.....
Overall...to me, on a heavily modded car running higher boost levels, its a must have! ;-)
Old Jun 3, 2006 | 05:58 AM
MOBlueTT's Avatar
Member
DE Track Days... 90 outside... 20 min non stop - 290 oil temp
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 3, 2006 | 07:27 AM
coasTTal's Avatar
Where did you put your oil pressure transducer?
Old Jun 3, 2006 | 07:57 AM
kodeTT's Avatar
Elder Member
Default Hans, who was that contact in FL where you got yours...
and was it a complete kit? or did you have to order the parts separately?
thx.
