Question re: Temp guage reading
Old Jun 4, 2006 | 08:37 PM
Breitling's Avatar
New Member
Default Question re: Temp guage reading
so I finally took my car into the dealership to get the temperature guage looked at again, my suspicion was the guage cluster again as the thermostat was changed to the green one not too long ago.
anyways, the temp guage goes up to almost the 3/4 mark as the engine gets hotter when i'm stopped at a red light. the dealership says that this is normal, i'm not so sure about this as they replaced the thermostat when i complained of this several months ago and the problem appeared fixed.
Old Jun 4, 2006 | 08:50 PM
GorTT's Avatar
Default Not, it's not. Mine doesn't do that w/temps well over 100 >
I'm guessing you may have a cooling fan out; the driver's side. Other option is the water pump - have you had the timing belt changed ever? Usually you replace the wp then; if not it's also possible the pump's failing.
There's an A/C readout to get accurate engine temps, try that and see what it says; also, does the temp drop when the A/C's on? Is the A/C cold, or not?
Old Jun 4, 2006 | 09:04 PM
Breitling's Avatar
New Member
Default i have less than 30K miles, i'll try checking with the A/C on.
the A/C appears to be functioning normally. A/C readout??
Old Jun 4, 2006 | 09:14 PM
GorTT's Avatar
Default use this link, and check the TT gallery links too >
actually, code 49 is the one you want (it's mis-labeled), but 51 gets close. This will give you engine coolant temps in celsius - 80-90 is ok, 100's still ok but you're getting on up there, and 103 - 110 does mean you might have a problem, esp after just normal driving, sitting in traffic.<ul><li><a href="http://www.wak-tt.com/tt/climatecontcodes.htm">http://www.wak-tt.com/tt/climatecontcodes.htm</a</li></ul>
Old Jun 4, 2006 | 09:31 PM
Breitling's Avatar
New Member
Thanks! I'll see if I can figure it out.
Old Jun 5, 2006 | 02:25 AM
Straz85's Avatar
Mine does it too, I have a new thermostat at home I have to put in...
volvopentaman
60
Mar 1, 2020 07:42 PM
madbaz
14
Dec 18, 2013 05:23 AM
Mister Bally
10
Aug 6, 2010 07:05 PM
140mph
Jan 19, 2008 04:02 PM
odelay12v
Jun 20, 2002 10:33 PM
