more on the horn.. ugh
Old Jun 6, 2006 | 06:04 AM
PracTTical's Avatar
Default more on the horn.. ugh
so audi of nashua wants to charge me a hundred bucks to toot my broken horn so they can say let's replace the engine... those tools will squeze every penny out of you if they can. So i did a little testing. my panic button does in fact work and the alarm works fine.. but the horn still doesnt work.. Is it a different horn? If it is, can i wire the regular horn button to the alarm horn? I just don't wanna get hosed on repairs here... also, i dont want to go through the pain in the *** job of replacing my horns to find out it was the switch all along.. thanks for any adivce guys, and sorry to those who hated my racing post.
Old Jun 6, 2006 | 06:10 AM
JustJeff's Avatar
Default alarm horn is different, it's under the cowl, under the wiper blades. No, you can't wire to it.
Get some Hellas
Old Jun 6, 2006 | 06:13 AM
TT_Nuge's Avatar
Senior Member
Default Different horn.
Get yourself a pair of horns from JC Whitney for about $20. Look for a post from Schwing, I believe he went that route. Search should pull something up.
Then you'll need a jack and a pair of jackstands. Pull your front bumper off and replace the horns. They are prone to failure and more than likely the cause of your problems. You'll want to get familiar with pulling the front bumper because if you hang out here much longer you're going to need to do it when you go with a set of clear corners, and Angel Eyes, and an FMIC....and numerous other mods that will require bumper removal.
Trent
Old Jun 6, 2006 | 06:21 AM
stilljester's Avatar
Member
Default You can just replace them yourself
Or if want to swing out to Troy, NY - I'd be happy to help you out. I think I may even have some stock horns around.<ul><li><a href="http://www.rpi.edu/~onksej/Audi%20Stuff/Audi%20TT%20Front%20Bumper%20Removal%20&amp;%20Hel la%20Horns.pdf">DIY</a></li></ul>
ehsix-4point2
16
Jun 15, 2005 04:41 AM
ChooChooNongNongHead
Dec 19, 2004 03:48 PM
rbuckstar
Sep 28, 2004 01:02 PM
chi_chung_wu
Feb 29, 2004 11:13 PM
XCCESS
Aug 7, 2001 08:03 PM
