timing belt kits
Old Jun 6, 2006 | 07:04 AM
WbgTT's Avatar
Default timing belt kits
I am at 65k on my 2001 TT. Other than the belt and the fuel pump and other belts what else do you recommend to be changed? Who has the best quality stuff for this?
TommyT
Old Jun 6, 2006 | 07:13 AM
maaliish's Avatar
Default belt is not the problem. Waterpump is.
You need to get a complete kit with t-belt, aux belt, waterpump, tensioner pulley, mounting bolts and G12 coolant.
I got mine from diselgeek
rotuspeed3's Avatar
Member
Default Dieselgeek
Complete kit with belts, seals, WATER pump, thermostat/housing, tensioner and a discount on G12.
Old Jun 6, 2006 | 07:17 AM
PGTT's Avatar
Default I believe that this is the kit from Dieselgeek.
Need to do this myself soon.<ul><li><a href="http://www.dieselgeek.com/Detail.bok?no=278">http://www.dieselgeek.com/Detail.bok?no=278</a></li></ul>
Old Jun 6, 2006 | 07:25 AM
jonchavez's Avatar
Member
ECS Tuning has a nice kit with a metal impeller water pump.
Old Jun 6, 2006 | 07:27 AM
YosemyTT's Avatar
Tensioner is the mail problem, AFAIK.
Old Jun 6, 2006 | 08:42 AM
maaliish's Avatar
Default I think that is the case on other Audis. Our cars are known for having a plastic impeller on the
wpump which breaks off, seazes and breaks the belt.
Old Jun 6, 2006 | 08:50 AM
XCLR8TT's Avatar
Senior Member
Absolutely replace the water pump... mine was missing about half the impeller at 59K
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 6, 2006 | 09:04 AM
stilljester's Avatar
Member
Just ordered mine from Dieselgeek
Old Jun 6, 2006 | 10:13 AM
YosemyTT's Avatar
Default Hmmm....I always saw those as almost seperate issues.
Plastic impeller is very bad but it slowly disintigrates rather than cause dramatic sudden belt failure. I had always thought the tensioner slowly lost pressure (it is a gas cylinder) and this led to a tooth-stripping belt skip causing the terrible damage we've heard about here so many times.
