Question about Big Brakes.
I'd also recommend stainless brake lines to prevent buldging when you pressurize the brake line. This will also lead to better peddal feel and less sponginess.
Finally all this is worthless if you have 2 year old OEM dot 3 brake fluid as it will just boil and fade the brakes.
Ironically a BBK will NOT necessarily shorten your stopping distance. However, after braking heavily on the track for 4 lapse it will disapate heat faster than smaller brakes thus giving you less fade and corresponding stopping distances. (IE: brakes failing because of too much heat or failing brake fluid).
Clear as mud?
Jeremy jeremy@matrixintegrated.cc
