APR Chip Concerns
Old Jun 12, 2006 | 09:54 AM
widstje's Avatar
Default APR Chip Concerns
I've got a 2000 TT with the 1.8T engine and I've purchased the APR chip upgrade with a N75 race valve from ECS. What additional parts should I be concerned with upgrading to handle the extra horses? DV? BOV? Hoses?
Old Jun 12, 2006 | 10:02 AM
TTinCT's Avatar
Rest In Peace
Default while the race N75 will produce a higher spike in boost, it also has>>
a tendency to bleed off quickly too...
Hoses will be fine....DV if OEM will go fairly quickly....some have been successful with BOV's, but most go with a good aftermarket DV.
Old Jun 12, 2006 | 10:05 AM
maaliish's Avatar
Default DV is at the top of the list. Then pay attention to leaky hoses which might become evident
after extra boost. Boost gauge is also a plus.
Old Jun 12, 2006 | 10:08 AM
TTinCT's Avatar
Rest In Peace
oh...and the MAF usually goes bad right after chipping if it has miles on it...
Old Jun 12, 2006 | 10:17 AM
Astronut's Avatar
Default I have 2000 TT 180hp with APR and >>
upgraded aftermarket DV. Stock original hoses beyond the turbo. Running stock N75 and boost machine. Holding 18-20 PSI boost with no problems.
I've replaced a couple vacuum lines due to wear and breakage from installing mods. That's normally where your problems develop.
Old Jun 12, 2006 | 10:19 AM
GeTT da NeTT's Avatar
Ouch! true dat.
Old Jun 12, 2006 | 10:23 AM
Astronut's Avatar
Yep, I'm on my 3rd :-/
Old Jun 12, 2006 | 11:38 AM
TTapsale's Avatar
Default I never had a N75 race valve . I recall some negative results with them...
After chipping w/ APR I did the ModShack Stage 3 set up as have many others & the results were great.The car runs so much better.Much more nimble & responsive IMO.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 12, 2006 | 12:01 PM
as350's Avatar
Member
I did the same. Same positve results with Modshack s3
RoberTT-WWCD's Avatar
Problems with the N75 'Race' and our cars. Go with the stock N75 and ModShack Boost Machine.
