My gas gauge has been on the fritz, and I got some>>>>>>
Old Jun 12, 2006 | 02:17 PM
1 Mean TT's Avatar
Default My gas gauge has been on the fritz, and I got some>>>>>>
techron to put in there, one question first. I don't think that it's my cluster becuase the miles till empty still counts down like normall, but is the gas idiot light in sync with the guage or the miles till empty? I ask becuase the techron says to put in an almost empty tank then fill up, and i was wondering how empty it should really be. I'm at 85 miles to empty and would normally go ahead and fill up, but I'm gonna wait I think. Let me know. Thanks.
Old Jun 12, 2006 | 02:22 PM
JustJeff's Avatar
It's your meter movement then. Techron won't help that.
Old Jun 12, 2006 | 02:32 PM
1 Mean TT's Avatar
should I take out the sending unit and clean that like RoberTT did?
Old Jun 12, 2006 | 02:37 PM
blackfnTTruck's Avatar
Default I think he means the movement in your cluster that is defective, Jeff replaced his......
himself with new meter movements, it's like an electrical coil.
Old Jun 12, 2006 | 02:39 PM
TTGram's Avatar
Member
Go ahead and fill up you just want it to mix as you fill.
Default Here is the original thread.......................
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1486795.phtml">https://forums.audiworld.com/tt/msgs/1486795.phtml</a</li></ul>
Old Jun 12, 2006 | 02:45 PM
RoberTT-WWCD's Avatar
Default I think before I would tear into the cluster, I'd clean the sender first...>>
and since you are almost empty, now's the time.
It take about 1 hour and not too hard. Just remember the fuel send and recv lines are under pressure.
Some have used a flatblade screwdriver and small hammer to loosen the retainer.
Good luck!!!
Old Jun 12, 2006 | 03:21 PM
JustJeff's Avatar
the meter movement, moves the dial pointer. it's in the cluster. you have a cluster problem.
 Pouria Savadkouei
 Michael S. Palmer
JDreher
A4 (B7 Platform) Discussion
Mar 12, 2014 12:13 PM
Basttion
Aug 21, 2008 03:34 PM
RSS
Jul 22, 2006 02:39 PM
sj6sp
9
Apr 22, 2003 04:22 PM
RSF
Feb 18, 2000 02:15 PM
