after hard reset gas gauge goes way past full and seems to be 1/4 tank out of sync
Old Jun 13, 2006 | 06:28 AM
WbgTT's Avatar
Default after hard reset gas gauge goes way past full and seems to be 1/4 tank out of sync
for a completely unrelated issue (repaced MAF and reset codes)I had disconnected the negative post and then replaced. Now my gas gauge is about a little under a 1/4 tank over the known quantity in the car (calc by trip meter and distance to empty). When filled the needle now pegs to the F side and falls below F only after several miles. Everything was normal and proportional before reset.
Old Jun 13, 2006 | 07:15 AM
sonus's Avatar
That's what my bad cluster does...could be that your cluster is bad
Old Jun 13, 2006 | 10:31 AM
WbgTT's Avatar
Default so the reset made the cluster suddenly go bad?? :-\
I've read all the prior posts on bad sending units and clusters but this seems a little different in the way it occured, etc... I can live with it but it's just a bit strange
Tommy
'01 silver TTQR
pretty much mod-free
Old Jun 13, 2006 | 12:54 PM
sonus's Avatar
Default Honestly, I don't remember what if anything could have prompted my gas gauge issue. Its been a
while since it started being out of sync. I definitely tried cleaning the fuel senders just in case, but that didn't fix anything (as you would expect since my trip computer was still reading properly.)
Titua1915
Oct 3, 2018 06:35 PM
driveaudi.colorado
10
Sep 22, 2012 02:17 PM
MiS4terTed
11
Nov 29, 2006 10:26 AM
JAB225
Sep 25, 2003 08:29 AM
TTRUBLE
Mar 27, 2000 05:46 PM
