Has anyone seen the Renn-Art ATP kit.
Old Jun 14, 2006 | 12:19 AM
1 Mean TT's Avatar
Default Has anyone seen the Renn-Art ATP kit.
it comes with unitronic tuning, 440injectors, the turbo, and a manual boost controler. Is this really all that would be needed to set this up properly and have it running at 300-330whp as they say? Sounds really fishy to me, but just seeing what you guys thought.
Old Jun 14, 2006 | 02:25 AM
GeTT da NeTT's Avatar
Default I did some research on the Unitronic chip and was disappointed. I suspect their HP numbers are
somewhat inflated. There is a lot of cause and effect.
A different turbo is a huge factor because of the heat generated by the K-03 and K-04 turbos. Switch to a Garrett and run GAIC software and you could spike 30 psi and hold 24psi. Modify the ignition timing and eliminate (or minimize) heat soaking and you are making some pretty fierce power.
That being said, there are several people on this board who have K-04s that are putting close to 250 HP on the ground and there ain't no flies on that.
Sorry for the rant. The answer to your overall question is probably.
Old Jun 14, 2006 | 05:26 AM
EvotechTT's Avatar
Junior Member
I've heard ATP is not very good, my friend had a kit on his Jetta, and boy did it have problems !!
Old Jun 14, 2006 | 07:59 AM
joe@vwvortex's Avatar
Default I wouldn't touch ATP stuff with a ten foot pole.......
actually 10 feet is kinda short :-)
myfootsmells
May 3, 2006 07:55 AM
EGainer
Jun 1, 2005 03:24 PM
nizmosx
Dec 30, 2003 09:57 AM
nosey
May 30, 2003 05:04 PM
Ray Khan
Feb 20, 2002 11:52 PM
