Gah, pulled up to get gas this AM and the damn gas lid won't flip up...
Old Jun 14, 2006 | 06:16 AM
JuanValdez's Avatar
Default Gah, pulled up to get gas this AM and the damn gas lid won't flip up...
of course, the center console button to work the back hatch won't either. The hatch will bump open with the key.
So, both the switches in the center console will not work (they light up with the running lights).
Is it a fuse or a loose connection to the console switches?
It's an 05' 3.2 fwiw.
Any suggestions?
Old Jun 14, 2006 | 06:18 AM
BoxcuTTer's Avatar
Default Re: Gah, pulled up to get gas this AM and the damn gas lid won't flip up...
Had this same problem about a month ago. Both gas flap and hatch buttons stopped working all of a sudden.
I opened the panel in the right side of the hatch, and pulled the flap cable manually.
The next day, they worked again and have worked fine ever since. Weird.
Old Jun 14, 2006 | 06:21 AM
JuanValdez's Avatar
Default I'll try that... car has been problem free for a year and a half now...
hate to start having "issues" now.
Old Jun 14, 2006 | 08:05 AM
KSpider's Avatar
I would also let your dealer know... it IS an 05...
Old Jun 14, 2006 | 08:28 AM
blackfnTTruck's Avatar
Default Had that happen to me, the trunk would not open with the console button.......
either, I reset the central locking system code and all was OK.
Old Jun 14, 2006 | 08:56 AM
JuanValdez's Avatar
Did you use vag-com to do that?
Old Jun 14, 2006 | 03:30 PM
Default Yes, oddly this happened after I had coded for the auto door locks, ......
recoded and has been fine ever since.
Old Jun 14, 2006 | 03:37 PM
JuanValdez's Avatar
Default UPDATE - left work, popped trunk w/ key to put umbrella in and..
now both the gas lid and trunk lid console buttons work.
curiouser and curioser...
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 14, 2006 | 03:49 PM
TTGram's Avatar
Member
Happened to me. Hit unlock button an extra time and they worked.
Old Jun 14, 2006 | 04:14 PM
MoreBoost!'s Avatar
New Member
Default For future reference: Backup procedure, RTFM!
There is a sheaf of dead tree slivers hiding in your dashboard which explains this in detail, but basically, open your hatch or trunk, then open the little access door on the passennger side. Inside you will find a cable which will manually open the fuel door.
