For those with a PhatNoise system...
Old Jun 14, 2006 | 06:49 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default For those with a PhatNoise system...
My wife's PhatNoise system is having a problem. After about a couple days of working just fine, the head unit reports "NO CD". Removing the cartridge, powering off the head unit, etc. will not bring it back online. If I unplug the cable where it integrates with the built in car cable, and plug it back in, it usually (80%) will work again, but only for a day or two again...
Anyone have similar problems and/or solution?
Old Jun 14, 2006 | 06:58 AM
XCLR8TT's Avatar
Senior Member
Have you updated the firmware?
Old Jun 14, 2006 | 07:29 AM
Tech Guru
Default No I haven't, but it's been working fine for about 6 months. Firmware should
not "corrupt" like that, right? I read a post on PhatHack.com that some cables for the VW/Audi systems don't have their pins fully seated in the connectors. That makes a lot of sense (pins might get wiggled free), so I will check that out. I guess I will update the firmware too, but I don't assume that will correct this issue.
Old Jun 14, 2006 | 07:36 AM
XCLR8TT's Avatar
Senior Member
Default Here is an article in the Knowledge Base concerning the "No CD" message
One of the items is the firmware and a couple of things to check with the cable.<ul><li><a href="http://www.phatnoise.com/kb/index.php?page=index_v2&amp;id=256&amp;c=9">Phatno ise kb</a></li></ul>
Old Jun 14, 2006 | 07:51 AM
Tech Guru
Thanks for the link.
Old Jun 14, 2006 | 07:58 AM
Felino Perdido-TT's Avatar
New Member
Default Hi there... you know, it did happen to mine, but only once so far...
After the panic and pissed off phase, I ended up reformating the thing, uploading everything all over again, and following the install steps like if it was a brand new device.
It's working fine ever since, yet I wasn't pleased by having to waste time like that.. :-(
btw: I can't find my CD anymore, and the voice promths are now very robotic... did you get the same?
Old Jun 14, 2006 | 08:11 AM
Tech Guru
Default The voice is one reason I don't want to upgrade the firmware. I heard it gets more "mechanical". I
like the voices they way they are now. You can hack the voice files and use different voice generators, but I don't want to mess with all that...
Old Jun 14, 2006 | 08:28 AM
XCLR8TT's Avatar
Senior Member
Default The only voice on the firmware is the one that says "Now browsing..."
The other voices that generate the actual name of albums and artist are in the Phatnoise Media Manager.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 14, 2006 | 08:44 AM
Tech Guru
Yup, and I think the german accented chick sounds pretty hot ; )
Andyly
Q7 MK 1 Discussion
Apr 14, 2014 07:09 PM
ash44
Audi A3 / S3 / RS 3
Jan 24, 2012 01:33 PM
ArchAudi
Audi allroad
9
Jul 11, 2006 11:11 AM
mike5
Jan 8, 2006 01:54 PM
