Brake update>>>>
Old Jun 14, 2006 | 01:24 PM
TTinCT's Avatar
Rest In Peace
Default Brake update>>>>
this one is worth noting. Turns out my brake failure yesterday was not due to the master cylinder failing....
Looks like one of the hose clamps on my Samco intake hose, apparently developed an affection for one of the metal lines out of the bottom of the resevoir. As the motor torqued over, it apparently has been rubbing ever so slightly against this line over time, and wore a hole right through!!! GO FIGURE...a little hose clamp, just the edge!!!
So the good news is it is fairly cheap to replace...the other good news nothing happened yesterday that could have been really bad!!....
Very strange....it is not like it stainless or anything....so it just goes to show ya...check your clamps now to be tight AND not to be rubbing against anything!!!!
All will be right in the world again!
Old Jun 14, 2006 | 01:32 PM
TTuned's Avatar
Interesting. Glad it was a simple solution!!
Old Jun 14, 2006 | 01:33 PM
Blue TooTh Fan's Avatar
Hans, glad everything is fairly OK, be safe!
Old Jun 14, 2006 | 01:35 PM
TTinCT's Avatar
Rest In Peace
usually is joe.....usually is....
TTinCT's Avatar
Rest In Peace
thanks Wayne....believe i will be safe! ;-)
Old Jun 14, 2006 | 01:36 PM
BTTI's Avatar
Senior Member
Valuable lesson there...luckily you (and hopefully many) learned the easy way!
Old Jun 14, 2006 | 02:04 PM
GorTT's Avatar
Default pre-flight checks! >
seriously, I need to book a couple hours every other month or so for "look-over" inspections.
Old Jun 14, 2006 | 02:44 PM
MarTT's Avatar
Default Just checked my samco/brake lines - I see exactly where you're talking about.
Mine showed no signs of rubbing <whew>. Glad it was an easy fix for you. This is the place, right?
<img src="http://images17.fotki.com/v313/photos/4/41970/1776469/01013-vi.jpg">
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 14, 2006 | 02:59 PM
TTinCT's Avatar
Rest In Peace
Default have not seen it yet Marty....>>
as it is at my tuner shop in CT...i am still in NJ!! ;-P
I will confirm that is the location, but judging by the pic there, i would say you are spot on!
Old Jun 14, 2006 | 03:02 PM
kodeTT's Avatar
Elder Member
Default wow. a simple little thing like that can cause major havoc. amazing, isn't it?
a nice warning to others.
i've got to check underneath the chassis myself. i usually do a once over when i swap out tires for the winter and vice versa.
glad it was minor repairs that you can DIY.
