Hello, My name is Jeff, and I'm an Idiot. NOW!, with Full Confession Inside
Old Jun 14, 2006 | 05:29 PM
JustJeff's Avatar
Default Hello, My name is Jeff, and I'm an Idiot. NOW!, with Full Confession Inside
I know I've given out a lot of text, pics and ballon-juice over the years here, why some of you accept this, I'll never know.
For `tis I have made a Classic Blunder.
I never closely inspected this freakin' hose.
This problem only affects '00-02 225 cars. They fixed this on the 03's (right?)
After spring cleaning and detailing, I noticed this area was getting more dirty, sooner.
The hose was more flexible.
I finally decided to invest in some decent SS clamps from McMaster before I tackled the job.
Tonight, it's been hot and muggy here, and the garage is steamy from a cooling engine.
I have 2 fans going to cool the car.
This was an actual pic of this vac. hose about 4 years ago.
<img src="http://pictureposter.audiworld.com/2847/vachose.jpg">
This is the OEM part in question.
The bottom hose section here is simply a pass-thru, or big rubber clamp. Another tube and crimp clamp goes on each end of a metal tube that goes through it. The tip two ports facing to the back connect 2 tubes, it the oddest arrangement.
<img src="http://www.loomknitting.com/auditt/images/oemhose1.jpg">
It fails right here.
The split got worse.
<img src="http://www.loomknitting.com/auditt/images/oemsplit.jpg">
With some silicone hose, like this, 5/8" or 16-17mm, and these 1/2" wide Stainless Smooth Band clamps., I routed the bottom hose 180 degrees by following this radius. Anything smaller would not fit in the space under the IC pipe, and it would kink the hose in the middle.
<img src="http://www.loomknitting.com/auditt/images/newhose1.jpg">
The top hose simply connects back on the tube here.
<img src="http://www.loomknitting.com/auditt/images/newhose2.jpg">
<img src="http://www.loomknitting.com/auditt/images/newhose3.jpg">
This is the IC piping back in place, the new hose wraps around like the other one. Tie-wrapped in to place
<img src="http://www.loomknitting.com/auditt/images/newhose4.jpg">
This makes a huge difference in over-all response.
I don't know why this type of vac. leak would not through a code.
I'm embarrased to tell you, yes, I could tell something was off ,but really the car was running well, just a whole lot better now.
Wow.
OK, like Hey!, all you that have this that have not checked this, do it now.
All those asking about what to look for in older TT's, ask and look for this problem.
Get the silicon hose sampler kit from hosetecqniques, and other smooth-band and T-bar clamps from McMaster. They ship in 2 days.
I'm gonna have fun driving tomorrow and try not to kick my butt too hard.
McMaster-Karr Parts;
45945K63
316 Ss Smooth-Band Worm-Drive Hose/Tube Clamp, 5/8" To 15/16" Clamp Id Range, 1/2" Band Width
or this different set
53175K31
Miniature Smooth-Band Bolt Hose &amp; Tube Clamp, 304 Stainless Steel, 5/8" To 45/64" Clamp Id Range
Old Jun 14, 2006 | 05:32 PM
TT_Nuge's Avatar
Senior Member
Oooooooo I HATE that guy.
stilljester's Avatar
Member
Hi Jeff and welcome to our group :-P
Old Jun 14, 2006 | 05:34 PM
TTinCT's Avatar
Rest In Peace
NoooBBBBB!! ;-P
fignewton's Avatar
I replaced that guy with copper. See picposter.
Old Jun 14, 2006 | 05:55 PM
XCLR8TT's Avatar
Senior Member
Default Well you've come to the right place. We have a lot of people who know how to
fix stuff and twice that number to riducule you.
Welcome to the club.
Old Jun 14, 2006 | 06:03 PM
MarTT's Avatar
Been there!
Old Jun 14, 2006 | 06:08 PM
TT_Nuge's Avatar
Senior Member
Default I found the one I replaced so if anyone wants it as a template for SFS to make a silicone one
send me an email and you can have it. As some of you remember I looked into doing this as a Group Buy either through Samco or SFS and neither worked out at the time, mainly because I couldn't find my original.
Well I found it, but have since gotten a factory replacement. And will soon not need it with the Dahlback mani and Del Rio Stg 3 kit. So if anyone wants it for the good of the group let me know and I'll send it out.
Trent
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 14, 2006 | 06:21 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default That actually looks quite nice! I could see doing it in Stainless...
<img src="http://pictureposter.audiworld.com/31296/copper4.jpg">
Old Jun 14, 2006 | 07:08 PM
TTapsale's Avatar
Default So this part doesn't exist on 180's? I've seen this problem before but couldn't find that hose.
I assumed I was looking in the wrong place.
