Alignment Issue: car is on machine and they can't get toe in spec...
Old Jun 15, 2006 | 01:15 PM
upstateTT's Avatar
Default Alignment Issue: car is on machine and they can't get toe in spec...
just had bilsteins/eibach/kmac installed. camber is fine... but they can't get the rear toe even close.. right now it's sitting at +.37 on both sides ... any ideas what to look for/check on?
could something possibly be bent?
that probaby explains the inner tire wear as of late too
ugh.
Old Jun 15, 2006 | 01:22 PM
TTinCT's Avatar
Rest In Peace
is it a full kmac or partial? and if partial, was it installed on the top or bottom?
Old Jun 15, 2006 | 01:23 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Adjust the toe by...>>
Moving the trailing arms via the slots at the pivot point. If that isn;t enough, put a full set of Kmacs on, not just the lowers.
<img src="http://images14.fotki.com/v219/photos/7/7305/63346/trailingarm-vi.jpg">
Old Jun 15, 2006 | 01:30 PM
upstateTT's Avatar
Default partial kmac...
it was installed on the top...
Old Jun 15, 2006 | 01:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default On the top?????????....Wrongo.....>
That's your problem. They go on the bottom. By pulling the bottom in, the Toe stays in better spec. With Eibachs you should be able to dial it to spec with no problem (1/2 kit on the bottom)
Old Jun 15, 2006 | 01:36 PM
upstateTT's Avatar
Default they called ECS and ECS told them top.. ha.
nice. well, ok..
as always, thank you thank you!
virtual beers and whatnot.
shannon
TTinCT's Avatar
Rest In Peace
ding!!! what Schwing said....time to re-install!
Old Jun 15, 2006 | 01:48 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Send them the bill.....
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 15, 2006 | 01:50 PM
upstateTT's Avatar
Default oh, i'm sure a few choice words will be exchanged.
i'm just happy nothing is bent!
i guess one of my springs was broken too... what the heck have i been doing to this car? i am so nice to it!
Old Jun 15, 2006 | 05:49 PM
upstateTT's Avatar
Default question re: reusing/moving bushings..
now that the new bushings are on the TOP arm is it going to destroy them to take them back out again? and i assume since the old ones were pushed out they should not be re-used again either correcto?
meaning.. i would need to have them replace the top bushings when the pull the KMAC bushings out and put them in the BOTTOM??
