Grabbing some 17x8 inch OZ Superleggeras...
Old Jun 15, 2006 | 10:39 PM
HugeTTs's Avatar
Default Grabbing some 17x8 inch OZ Superleggeras...
Going from my 18x7.5 inch Racing Hart C2's.
What size tire should I go with, I do-NOT understand all this tire stuff. All I've learned is that a 40 series tire is taller than a 45. All that 205 225 bs... yeah, I'm clueless.
I want the widest I can get.
Old Jun 15, 2006 | 11:21 PM
InTTruder's Avatar
AudiWorld Awesome User
Default 235/40 is SHORTER than 235/45: .....
the /40 or /45 is height of the sidewall as a % of the width.
Tire Rack website can show you which are the corrrect fitments for that width rim.<ul><li><a href="http://www.tirerack.com">Tire Rack</a></li></ul>
Old Jun 16, 2006 | 03:05 AM
nikhil's Avatar
Default where are you getting 17x8 SLs?
run 245/40-17 if you want *the* widest tire for the wheel, but you might need a small spacer in the front to clear the strut.
Old Jun 16, 2006 | 06:04 AM
rotuspeed3's Avatar
Member
Default While you were sleeping in math class...
tire sizes:
aaa/bb/cc
a is the width of the tire in mm
b is the ratio of sidewall to width, ie 205/45 means that the sidewall is 45% of the width or 92.25mm
c is the diameter of the wheel in inches (254mm/inch)
Formula for height of a tire and wheel combo:
(c x 254) + [(aaa x .bb) x 2]
Or you can just click below<ul><li><a href="http://www.miata.net/garage/tirecalc.html">click</a></li></ul>
fapmap
Wheels & Tires Discussion
May 1, 2007 03:08 PM
red4kcsq
Feb 22, 2006 06:30 AM
Crisqo09 T.O.
Feb 4, 2002 07:23 AM
AndyA6
9
Aug 18, 2001 01:01 PM
Stephen S.
Jan 28, 1999 04:42 PM
