REVO and PFLOW
Old Jun 15, 2006 | 11:44 PM
element2050's Avatar
New Member
Default REVO and PFLOW
I just got REVOed. boost spikes 22 holds at 20 for a bit then drops to 15 and holds with stock airbox.
Today I installed a PFlow intake and now boost spikes at 16 and holds at 11...... not sure whats up with that any ideas? BTW the car is running cooler and I checked all connections.
Update I changed the boost setting on SPS 3 to 6 and now I spike and hold at 15. I'm running 91 gas.
What settings are people using on REVO wiht 91 gas?
Old Jun 15, 2006 | 11:56 PM
VorsprungTT's Avatar
im no genious, but after i installed an air filter, my maf went bye bye, how old is yours?
Old Jun 16, 2006 | 03:50 AM
TTinCT's Avatar
Rest In Peace
ding....that and VAG is your friend!
Old Jun 16, 2006 | 03:52 AM
02TTK04's Avatar
Member
Default Maf pushed over the edge. Very common when adding a high flow air intake. You can test with a VAGCOM
or just replace the MAF.
Old Jun 16, 2006 | 08:22 AM
New Member
Default less then 6000 miles on it.
Old Jun 16, 2006 | 08:23 AM
New Member
Default Re: Maf pushed over the edge. Very common when adding a high flow air intake. You can test with a VA
How do I test it?
Old Jun 16, 2006 | 08:26 AM
TTinCT's Avatar
Rest In Peace
Default connect vag...log block 2 or 3 for g/sec across MAF>>.
if it is anything less than 160g/sec on a 225 TT....then it is bad..on a 180, its about 140g/sec.
All logging needs to be done while car is moving...
graviTT
Jan 20, 2007 10:30 PM
Vodka G
Feb 7, 2006 09:13 AM
leosphere
Aug 18, 2005 01:48 PM
JBirdS4
Aug 26, 2004 05:44 PM
ivansis
Sep 20, 2001 06:34 PM
