Overboosting Issue - Any Ideas? What should I check/replace?
Old Jun 16, 2006 | 05:19 AM
Kyle K: TampaS4's Avatar
Default Overboosting Issue - Any Ideas? What should I check/replace?
Our 225 TT is GIAC Chipped with everything else stock. We replaced the MAF and did a pressure test. The car will boost up to 25psi and possibly over(the gauge doesn't go higher than 25).
EDIT - it never over-boosted like this after the chip install only until about 6 months later it started acting up.
Only things i can think of are N75 valve or the Diverter Valve. Anything else that could be a possibility?
We want to get a boost machine to control some of this, but I don't think we should until this problem is addressed.
<img src="http://pictureposter.audiworld.com/9102/all3.jpg">
Old Jun 16, 2006 | 05:20 AM
TTagz's Avatar
Senior Member
doesn't sound like a problem to me!
Old Jun 16, 2006 | 05:49 AM
TTinCT's Avatar
Rest In Peace
Default double check the hose from the N75 valve to the wastegate>>>
if it is cracked and you have a leak, then you can overboost...
Old Jun 16, 2006 | 06:31 AM
nikhil's Avatar
Default is it throwing codes?
if you decide to replace the hose from the N75 to the wastegate, see my writeup from yesterday...
Old Jun 16, 2006 | 07:33 AM
Default No, its not. But that may be because the GIAC chip is more lenient on boost fluctuations..
thanks for the help.
AudiTT225CT
Jul 1, 2009 11:51 AM
hahnmgh63
Mar 20, 2009 10:51 AM
AWD2KS4
12
Jan 7, 2008 10:18 AM
NevaFolow
Jun 14, 2007 03:03 PM
twoquattros
Aug 7, 2005 07:39 PM
