headlight removal question. My car did not have
Old Jun 16, 2006 | 06:55 AM
Basttion's Avatar
Default headlight removal question. My car did not have
the fourth bolts holding the headlight in on the outside edges of the lights. Any ideas why?
UPDATE: I have the headlights completely apart!
Old Jun 16, 2006 | 07:03 AM
TTinCT's Avatar
Rest In Peace
Default IIRC....there are only 3 bolts....two top, and one on the inside near>>.
the radiator.....the outside edge is held by a tab that slides into the fender lip...
Old Jun 16, 2006 | 07:19 AM
Basttion's Avatar
Default That's all I have. But if I'm reading this fotki correctly, it says I should have four.
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/lighting_systems/osirdesign_smoked/93_adjustment_screw.html">mcphill's</a></li></ul>
Old Jun 16, 2006 | 07:27 AM
TTinCT's Avatar
Rest In Peace
are you including the adjustment screws in that count???
Old Jun 16, 2006 | 07:37 AM
stilljester's Avatar
Member
There are three screws and one tab catch on the rear of the housing
Old Jun 16, 2006 | 08:03 AM
Basttion's Avatar
Yes.
Old Jun 16, 2006 | 08:05 AM
TTinCT's Avatar
Rest In Peace
Default then the correct count is 5....there are two adjustment screws>>>
but they are part of the housing. There are two tab bolts on top, and one mounting screw on the inside tab....that is it.
Basttion's Avatar
Default Another question*** My headlight housings don't have the rubber plug covering the hole through
which the angel eyes instructions say to run the wiring. Did anyone else have to go a different route because of this?
Should I just drill the hole out and not worry about the rubber plug stopping it up later?
TIA
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 16, 2006 | 08:08 AM
Basttion's Avatar
The two adjustment screws on top are white plastic, correct? That makes mine nornal if so. )
Old Jun 16, 2006 | 08:18 AM
TTinCT's Avatar
Rest In Peace
they are....
