Thouse of you with 225s and boost gauges, please confirm what your car idles at.
Old Jun 16, 2006 | 07:06 AM
maaliish's Avatar
Default Thouse of you with 225s and boost gauges, please confirm what your car idles at.
Mine idles at -16 to -18 (mostly at -16), but as per some posts on the board others noted values closer to -20 and as low as -22. Can anyone please confirm what the idle should be? I wonder if I have another leak. Also, I noticed that when stereo is on the vacume readin goes up a notch. For example: yesterday I was standing at a light and noticed my gauge show vac at -18...when I turned my radio on vac reading increased to -16. I'm guessing extra current draw effects the alternator and hence puts more strain on the engine at idle...just never thought I'd notice it on the gauge.
Old Jun 16, 2006 | 07:11 AM
TonyStarkz's Avatar
usually 18-20. Turn on the A/C and its all over the place though.
Old Jun 16, 2006 | 07:20 AM
TTinCT's Avatar
Rest In Peace
looks fine to me...mine is in the range Tony notes below...
Old Jun 16, 2006 | 07:22 AM
SporTTy's Avatar
Junior Member
mine idled parked at 21 but I have a stock 180 so not sure if for a 180 if mine is correct
Old Jun 16, 2006 | 07:26 AM
maaliish's Avatar
hmm....so looks like mine should be a bit lower.I never see below -18 unless I'm in a gear cruising.
Old Jun 16, 2006 | 07:39 AM
GorTT's Avatar
Can I play anyway? -20 idle, +21 peak on my 180...
Old Jun 16, 2006 | 07:41 AM
VorsprungTT's Avatar
Default I idle at -19, I think -20 is no leaks, and mechanical boost gauges are all a little bit inacurate..
at least from what I hear. They will be off +/- 1. goto homedepot, grab a friend with an aircompressor and do a pressure test.
TTagz's Avatar
Senior Member
sounds like you may have a slight vaccuum leak
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 16, 2006 | 07:45 AM
TTGram's Avatar
Member
Default Could be your gauge is off. Looks close enough. I wouldn't lose any sleep over it.
Mine says -2 with engine off.
Old Jun 16, 2006 | 08:29 AM
element2050's Avatar
New Member
20 all the time
