VAG COM AND SPS 3
Old Jun 16, 2006 | 08:30 AM
element2050's Avatar
New Member
Default VAG COM AND SPS 3
Is there a USB cable that will plug into the SPS 3 so I can use it like a VAGCOM cable?
Old Jun 16, 2006 | 10:14 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default I THINK you are asking if you can put an extension on an SPS3... but I am not sure... How does USB
enter in to an SPS3 discussion at all? Schwing makes an OBD Port Extender, and you could use that to make a more accessible place to plug in both the SPS3 and the VAGCOM - is that along the lines of what you are looking for?
Old Jun 16, 2006 | 01:35 PM
New Member
Default There is a plug in the SPS 3 at the bottom. If i could get a usb cable
There is a plug in the SPS 3 at the bottom. If i could get a usb cable with the right connector and could use it for VAGCOM without buying the VAGCOM cable
LarryMc
Jul 29, 2004 06:18 PM
/\/\eTTalicA
May 30, 2003 10:03 AM
leeep
May 2, 2003 12:32 PM
a4neil
Feb 17, 2002 11:36 PM
