tt takes its first road trip....
Old Jul 3, 2006 | 10:29 PM
ginameyerr's Avatar
New Member
Default tt takes its first road trip....
alright, so i'm currently on vacation with my tt (my first roadtrip of over 100 miles!) yay :-)
well, eveything has been going smoothly, except i noticed two times while parking on a steep decline (with the wheels toward the curb) that my brake lights were staying on...i thought it was some sort of automated parking light...but after opening up the panel, turns out a 3mm part of the little key under the brake pedal was slightly worn ...it was an easy fix for a friend of mine.
BUT, because i had to get a battery jump (original battery and the car is an april 01 production)...my stereo doesn't turn on anymore!...did a fuse blow or is this the anti-theft in action? (i get no power in the system whatsoever, nothing on the lcd screen). checked the fuse box, and they were all good. anyone?
PS for Sal: Mechanic Vic is awesome!...Coincindentally, I had him check my car out last week- just to give me peace of mind-and he says my tt is very clean, but to keep my eye on that original battery. so as my luck would have it...no music on the way home!
Old Jul 4, 2006 | 03:35 AM
VenTTed's Avatar
Default There is a fuse on the back panel of your headunit...
You'll need to find, make or acquire special "keys" to get the HU out of the slot, but from there you can check the fuse, it's probably blown.
Before you pull the HU check to make sure you have the manual that contains your HU theft protection key - it's a 4-digit number. If you don't have that, this is a dealer repair only. That key will enable you to get the radio working again from "SAFE" mode to operational.
I dunno anything about that Brake issue - never seen it. And yes, that battery was long overdue for replacement.
Enjoy the car - sounds like you are having fun!
Old Jul 4, 2006 | 03:58 AM
mobsTTa's Avatar
Radio code may also be in spare tire well
Old Jul 4, 2006 | 05:14 AM
SparTTan's Avatar
Bad brake light switches are common. Happened to me twice.
Old Jul 4, 2006 | 08:24 AM
ginameyerr's Avatar
New Member
Default Thanks guys! TT and I are off to audio-man tomorrow, thankfully I have
the code in the service record book on that little card you're suppose to detach from the sound system manual...
guess the next time i get a jump the stereo should be off?? ...although, i still haven't replaced the battery. <---CHEAPPP... Hey I figure it's working fine for the moment...
Old Jul 4, 2006 | 10:41 AM
kodeTT's Avatar
Elder Member
Default no battery means no music on the way home...
worse than that...car won't start either. so if its the original, i would change it.
Missyp
Jul 11, 2015 06:44 PM
Phatjoe
Jan 15, 2015 06:50 PM
SungTT
Jan 18, 2010 06:18 PM
bronco
Apr 1, 2009 02:27 PM
SilvrBulleTT
New England Discussion
18
Jun 28, 2007 09:18 PM
