Is everyone using the Ross-tech vag??? if not then what???
Old Jul 3, 2006 | 11:41 PM
DeadLy's Avatar
Junior Member
Old Jul 4, 2006 | 12:00 AM
HACK THS's Avatar
Stick with Ross-Tech!
Old Jul 4, 2006 | 05:52 AM
tcheat's Avatar
Default Vag-check with IPAQ PDA
It is ok for my limited purposes (reading & clearing codes) but I don't think that it can do everything that VAG-Com can do.
Here's the website if you want to check it out:
http://www.arlab.it/vc/main.html
Old Jul 4, 2006 | 07:20 AM
OldSchool AG's Avatar
Senior Member
Default even the local dealer techs use Ross-Tech as there is only 1 VAS 5051 in the shop
of course they have to use the 5051 for all warranty work, so they can get paid (it wirelessly transmits the repair data back to the server)
Old Jul 4, 2006 | 01:33 PM
DeadLy's Avatar
Junior Member
Default soo.....which one would i want to buy (complete noob here)
do i want the:
key-usb vag com
hex-usb+can vag com??
TIA
Old Jul 4, 2006 | 01:56 PM
HACK THS's Avatar
Default Have you looked here....
I have the HEX-COM, LOVE it. But it looks like the Key-Com is what I might get now. Looks like they changed their interfaces to have the "key" built into all their cables. I would look at the site I attached here, and see if you need those other "YES" options. If not, I would save the $100 and go Key-USB if I do not have the need for the other options. Personally I would go HEX-USB cause I want to make sure im always covered, and I always try to help out friends with their Audi's and who knows what will end up in my drive way! <ul><li><a href="http://www.ross-tech.com/vag-com/interfaces.html">http://www.ross-tech.com/vag-com/interfaces.html</a</li></ul>
Old Jul 4, 2006 | 06:36 PM
jhoeppel's Avatar
Default ProDiag on a Palm Tungsten... >
Works great for code checking/clearing, reading measuring blocks, changing basic settings and the like. And the form factor is very convenient. But graphing is less convenient--you can watch graphs on screen, but if you want to review them later, you need to save them as data files, sync them to a PC and look at them in Excel or another spreadsheet program.<ul><li><a href="http://www.shadetreesoftware.com/">ProDiag info here</a></li></ul>
Old Jul 4, 2006 | 11:11 PM
DeadLy's Avatar
Junior Member
thanks hack i'll probably go with the hex usb
 Pouria Savadkouei
 Michael S. Palmer
S4gasm (LoTR)
Dec 2, 2006 01:14 AM
milman1096
VAG-COM Discussion
Jul 15, 2004 07:43 AM
ATH
Dec 15, 2003 01:39 AM
hondakiller
Dec 11, 2002 06:45 AM
Samten
Nov 30, 1999 05:29 PM
