To anyone keeping track, wilwood's brake kit
Old Jul 4, 2006 | 02:41 PM
nikhil's Avatar
Default To anyone keeping track, wilwood's brake kit
not the RPI 13" kit, saves just about 30lbs of unsprung weight (14lbs/side vs. 29lbs/side). the difference in steering response alone makes the upgrade worth it!!
Old Jul 4, 2006 | 02:52 PM
QS -'s Avatar
wow. really? what is the rotor dia and pad size?
Old Jul 4, 2006 | 02:54 PM
nikhil's Avatar
rotor dia. is 12.2"(IIRC) vs. stock 12.3"....i don't know the pad size....
Old Jul 4, 2006 | 03:16 PM
QS -'s Avatar
Default oh...so it is a weight reduction kit? are the rotors at least 2 piece?
I dont mean to come off like an ***, but I am not sure why i would want to reduce my rotor surface area.
i am searching their site, but i have yet to see TT applications.
they have floating rotors and 4 or 6 pistons, right?
Old Jul 4, 2006 | 03:22 PM
InTTruder's Avatar
AudiWorld Awesome User
Links?
Old Jul 4, 2006 | 03:30 PM
shifTT's Avatar
Junior Member
Default 4 piston billet Dynapro calipers with 2 piece (aluminum hat) 12.19" vented rotors
<ul><li><a href="http://www.wilwood.com/PDF/ds469.pdf">http://www.wilwood.com/PDF/ds469.pdf</a</li></ul>
Old Jul 4, 2006 | 03:50 PM
OldSchool AG's Avatar
Senior Member
Default I would assume there is some feel and modulation improvement due to better calipers, but....
yeah the swept area reduction is a bit of a turn-off for me since a brake upgrade would be done solely to reduce fade on the track (which I've never felt with stock calipers/rotors and upgraded pads).
Old Jul 4, 2006 | 03:51 PM
TTinCT's Avatar
Rest In Peace
Default 4 piston for the TT>>>
and reducing the rotor area in this application is not all bad. The OEM rotors are not as thick as the wilwoods..Now i have no conclusive evidence that one offsets the other...only my experience with the RPI setup..(yeah, i know it is larger)...
My only bitch with the setup is the pad they send with it..way too agressive. The Ferodo DS2500's are amazing...albiet a bit dirty...but totally worth it!
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 4, 2006 | 04:06 PM
QS -'s Avatar
good points
Old Jul 4, 2006 | 04:39 PM
nikhil's Avatar
Default true
pedal feel should be better, and going to a 2-pc rotor should definitely help with the fade issue (yes I've faded the stock setup at the track..). We'll see how this setup does at the track next weekend!
