anyone have Dahlback manifold + Shwing stage 3 ?
Old Jul 5, 2006 | 06:22 PM
TTcrane's Avatar
New Member
Default anyone have Dahlback manifold + Shwing stage 3 ?
Just installed the manifold and got a check engine light, I was thinking maybe its not compatible with Steve's setup?
thanks Matt
Old Jul 5, 2006 | 06:25 PM
kodeTT's Avatar
Elder Member
what else are you running? like what chip? you have an adjustable FPR? more info needed.
Old Jul 5, 2006 | 06:26 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Shouldn't be a problem....>
Several have or had that set-up (NasTTcar, Axeyrcat and more). Got all your Vac lines routed and plugged in correctly?
Old Jul 5, 2006 | 06:27 PM
TT_Nuge's Avatar
Senior Member
Default I know it doesn't help but I was going to. If the light was immediate I'd say something didn't
get reconnected properly.
Old Jul 5, 2006 | 06:32 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Like....
Throttle body plug or Manifold temp sensor....
Old Jul 5, 2006 | 06:43 PM
AxeYrCat's Avatar
Member
Default I ran with the Dahlback manifold and Modshack Stg. III for 20K miles.
I didn't have any problems...
Could be a lot of things.
Old Jul 5, 2006 | 06:55 PM
TTcrane's Avatar
New Member
Default Re: what else are you running? like what chip? you have an adjustable FPR? more info needed.
thanks for the replys
apr chip
shwing stage 2 actually
upgraded fpr
evo heatshield
etc...
the cel came on the second time I started it, it seems to run fine, taking it easy of course,
I don't have a vag com
I guess i'll recheck everything and go from there
thanks
Old Jul 5, 2006 | 06:57 PM
AxeYrCat's Avatar
Member
Upgraded? As in 4-bar or as in adjustable? It could be a *lot* of things.
 Pouria Savadkouei
 Michael S. Palmer
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Since the ..>>
Manifold temp sensor is out of sight on the Dahlback, are you sure you plugged that back in?
Old Jul 5, 2006 | 07:00 PM
TTcrane's Avatar
New Member
shwing stage 2
apr
evoheatshield
exhaust
etc...
the cel came pretty much right away, pretty tough install, seems to run normally and the idle is steady, I guess I'll recheck hoses etc. and go from there
thanks
