Electrical Issue on a Passat VR6
Old Jul 6, 2006 | 06:34 AM
TonyStarkz's Avatar
Default Electrical Issue on a Passat VR6
Couldn't get much help searching other boards; so I figured I'd pose the issue to you fellows/ladies:
The car is a 94 Passat VR6. The issue (other than figuring out why the parking brake doesn't work-probably needs a new cable) is that the battery discharges overnight. It was found by the previous owner to have a 1.5v current draw after the car is turned off. In my own test; I disconnected the negative cable and grounded the battery with a test light. Since there is a current draw; the light was lit. I proceeded to pull and replace all the fuses I saw under the dash and the only fuse that would cause the test light to dim was the interior lights fuse (15) even though i believe i had the interior lights off. Other than that the automatic seatbelt motors don't work so I wonder if that is pulling current trying to run the motor; but i can't seem to find the fuse for them. Anyone have any ideas/suggestions?
Thanks all.
Old Jul 6, 2006 | 06:50 AM
MaxHedrm's Avatar
Default Shouldn't you be able to unplug the seats to see if that helps?
Or rather the seatbelt motors.
Old Jul 6, 2006 | 07:12 AM
JustJeff's Avatar
Default You need to isolate the power taps to see where the draw goes. Connect a DVOM as an ammeter to
isolate which voltage run from the battery or at the fuse box has the draw.
The previous measurment is suspect, as you cannot measue a "current draw" in volts.
your statement that you have a 1.5v current draw is questionable.
You may mean, or perhaps you did not understand what the previous ownewr meant. Perhaps it's a 1.5 Amp draw, which would be a lot.
Suspects are the radio power amp not turning off.
You can isolate the power to the fuse box by pulling the main relays under the dash, the 30-40A ones, or the 75A relays to see where the drop is.
If the Passat has a similar voltage "manifold" like on the TT, you can at least find out which brach has the draw.
Old Jul 6, 2006 | 10:02 AM
TonyStarkz's Avatar
unplug them where though? I guess I can pull off the panel and follow the wires to the plug.
Old Jul 6, 2006 | 10:09 AM
TonyStarkz's Avatar
Default Very possible that I mis-quoted the figure for the current draw...
but I definately know it was 1.5 something. It is enough that I can leave the battery connected for a few hours and it will be fine; but overnight and it dies. I'll try the relays to see if one of them is pulling the current. Thanks for the suggestions.
Old Jul 6, 2006 | 10:16 AM
JustJeff's Avatar
they are right under the front of the seat
Old Jul 6, 2006 | 11:55 AM
TonyStarkz's Avatar
cool I'll try unplugging those tonight.
Old Jul 7, 2006 | 01:29 PM
TonyStarkz's Avatar
checked and they are already unplugged...thanks though.
 Pouria Savadkouei
 Michael S. Palmer
A 8
12
Jan 7, 2024 03:46 AM
danfil
26
Sep 14, 2015 10:41 PM
ImQuattro®
Audi Original "S" Cars
15
Dec 10, 2008 06:56 PM
DMW96A6
Audi 100 / A6 (C4 Platform)
Sep 10, 2005 04:03 PM
greenaudi100
Jan 26, 2004 06:42 AM
