scheduled service light
Old Jul 6, 2006 | 07:04 AM
BoxcuTTer's Avatar
Default scheduled service light
"Service!" notice comes on when I start the car. The notice has been counting down from 800 miles or so. It's been about 10,000 miles since I bought it, and I've done two oil changes myself since then.
Is this just an oil change light? Do I need to get a VAG-COM to turn it off?
With 48,570 miles I should probably take it in and have them replace the timing belt and water pump anyhow, huh? Anything else I should have done? I haven't had to take it in for service since I bought it in August '05. (knock on wood).
Old Jul 6, 2006 | 07:08 AM
TTapsale's Avatar
Default There's a procedure to shut it off w/o Vag-Com.I can't remember what...
it is though.I think it's in the owners manual.Or do a search.It's been discussed before.A TB replacement would be wise now IMHO.
Old Jul 6, 2006 | 07:20 AM
jhoeppel's Avatar
Default you can turn if off w/o any tools...>
the procedure is in the owner's manual (in the instruments and controls section). I just did it last weekend.
I think you turn on the ignition while pressing in the right instrument cluster button... keep it pressed while then pressing the left cluster button until the service reminder resets to 10,000mi. Better check the manual to make sure, though.
BTW, it defaults to 10,000mi, but if you really need to change your oil at 5k intervals you might want to reset the interval, and for that you'd need a Vag-com or ProDiag.
Old Jul 6, 2006 | 07:37 AM
stilljester's Avatar
Member
Default Yes, you can shut if off without any special tools...
Double check your manual but I believe its just as 'jhoeppel' says:
Turn car off.
Hold right button below screen while turning key to on position.
Then press the left button below screen until it resets.
Old Jul 6, 2006 | 07:47 AM
OldSchool AG's Avatar
Senior Member
well-placed hammer blow?
Old Jul 6, 2006 | 11:04 AM
VorsprungTT's Avatar
how do you change the interval to 5k? that would be useful
trimike
Nov 13, 2008 08:00 AM
BlackS4tt (Josh)
22
Jul 30, 2005 06:22 PM
DirtySanchez
Oct 16, 2002 10:34 AM
EdTT
Oct 25, 2000 02:20 PM
