Will a Revo SPS3 work for a MY2000 FWD TT, engine code ATC?
Trent
On your fuel situation, unless you have programming to take advantage of 100+ octane I wouldn't waste my time and money. An SPS3 will change things within a relatively small window and I think they have a "race" fuel setting . Your computer does this automatically to some extent BTW, by advancing timing up to the point of Knock, then retarding a bit ( within a relatively small range). High octane fuel also burns slower, so unless the programming exists to deal with it, your car may not run any better. Buy a tank and see what happens. you may or may not be pleased with the results. I would concentrate on some cooling mods too. The cooler the temps read at the manifold the greater timing advance and power you will get. This makes a huge difference (ie: FMIC)
