MAF kaputt....need HELP (long)!
#17536 Fuel trim (mult.) system too lean (P1128)
They also checked the readings:
Data block values 08/00 field 9: 116, field 10: 190
08/032 field 1: -2.3%, field 2: 24.2%
They claim that these readings are bogus and therefore the MAF sensor is broken. They also checked for leaks in the intake but found none. Reading older posts, this seems a reasonable diagnosis.
They want $315 for the job ($237 for the part and $78= 0.8 hours for labor). I saw from older posts that Audi extended the warranty on this part to 70,000 miles. Unfortunately, I am at 83,000. I also see that one can order the parts for the VW 2.0L engine here:
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=1326
Then unscrew the sensor and replace it in the MAF body. This seems to be an "easy" job, so I would be inclined to try it myself.
Can anybody who has tried this please post some instructions/hints?
Thanks.
If you have 180 (usually engine code ATC) you can buy the correct MAF (not the VW one) from ECS for around $190 and still save money. I am running the VW one in a Modshack **** with no problems.
Not sure about running the VW MAF in the 225 engine maybe someone else can chime in.
Install is easy 5 min job if you're replacing the entire MAF (housing and all). Two hose clamps on either end, unplug sensor wires, out with the bad in with the good and reverse. I've used the VW MAF intact (did not swap sensor to old housing) but if you want to swap sensor just use vise grips to get screws out.
<img src="http://images8.fotki.com/v153/photos/4/435091/1703547/connectingtheMAFfromthehousing-vi.jpg">
For more directions, follow the link, and follow steps 11-16 only...<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/modshack_stuff/bamm/">Follow steps 11-16 here...</a></li></ul>
i really don't understand why people do this... i mean it MIGHT work depending on some variables, but what's the point? just to be different? sorry, but i'll be a conformist here. running incorrect MAFs could have long term implications like killing the kitty cats... not good... and $$$$.
Many here have had success with the VW 2.0 MAF P/N: 06A906461A. As long as the O2 sensors are functioning properly the ECU will adapt the A/F ratio to compensate for the slightly higher g/s output.
I STFA and if I have it right 180 ATC/AWP MAF is 06A906461D and 225 AMU MAF is P/N: 06A906461E
